Bridgeport Mill Tachometer
Don’t touch it! It’s terminal!
Have you tried looking at Solarbotics here in Calgary they are situated around 32Ave and 12St in the north.
Yup... kind of pricey. I got a switch, enclosure and 9V battery holder there.
still working on my mill controller, ran across a MUCH better tachometer framework. This library uses the main system clock to measure microseconds between pulses, takes maybe ten pulses and averages the time.
(correction - 30 pulses, should have read the code)
In testing it can easily track from1 Hz to 2500 Hz with good accuracy. 60 RPM to 150k RPM with my single trigger per revolution. Is not affected by other code in the loop, which I proved by adding a delay-flash-an-LED-delay after the frequency function, and changing the length of delay has no effect on accuracy.
The library is available in the usual Arduino <Manage Libraries> menu.
Here's my testing code:
#include <FreqMeasure.h>
// pin 8 is input
void setup() {
Serial.begin(57600);
FreqMeasure.begin();
pinMode(LED_BUILTIN, OUTPUT);
pinMode(8, INPUT);
double sum=0;
int count=0;
void loop() {
if (FreqMeasure.available()) {
// average several reading together
sum = sum + FreqMeasure.read();
count = count + 1;
if (count > 30) {
float frequency = FreqMeasure.countToFrequency(sum / count);
Serial.println(frequency);
Serial.println(frequency *60); // converted to RPM
sum = 0;
count = 0;
// otherstuff
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(10); // wait a bit
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
// pin 8 is input
void setup() {
pinMode(8, INPUT);
double sum=0;
int count=0;
void loop() {
count = count + 1;
if (count > 30) {
sum = 0;
count = 0;
// otherstuff
that is the best method of sampling to achieve fast and accurate rpm returns
