So i assume you ran across the parking lot yelling "start the car"
YUP!!!! And pinch me I must be dreaming
Just make the hole one size smaller that the stock you have. Turn the brass down to press into the hole.
I would not go by drill size to make the brass pin as a drill will most likely give a hole that is oversized.
Measure the hole and make the brass oversized wrt the actual hole dimension.
Well, there you go! Nice job.
Those brass caps have enough meat on them that you can re-face them when they wear.
Did you change out the 1/4-20 bolt for a 7/16-14 as per RobinHoods suggestion?
