RobinHood
What do you have for brass stock? I would base it on that.
1/4”, 5/16” or 3/8” would probably work. You could always leave a bit of your taper you have on the fingers already to make the brass “blend in” a bit more. Use a smaller rod first and see how that looks; you can always go bigger if it is too small. Really up to you.
Just make the hole one size smaller that the stock you have. Turn the brass down to press into the hole.
I would not go by drill size to make the brass pin as a drill will most likely give a hole that is oversized.
Measure the hole and make the brass oversized wrt the actual hole dimension.
