3D Printing - machines owned by members
I invite you to please post a note with the machines you own and what you think about them. Pictures of machines and results are always welcome.
kevin.decelles
Geeetech I3 pro B
Basically a prusa i3 Chinese clone, tims of available parts and hop ups
Tom O
I’ve got a Makerbot replicator 2x that I haven’t used in a while, the last time was a good year ago when putting a computer fan on my mill in the basement
Colten Edwards
Fabricator
home-made delta from 2040/2020 extrusion with a 330mm 120volt print bed, 1 meter high. currently using a "re-arm" 32bit board attached to a ramps 1.5 board with TMC2100 drivers and dual extruders :)
Colten Edwards
Fabricator
although this is not mine, I have printed one of these. Just need to put the shroud on, and it will be fully functional.
printed in two pieces. I have 390mm's of Z height which has increased recently with the purchase of new linear rails to probably around 480mm. this is a rough estimate though.
Ok I now own a prusa mk3. Just got it going. Standard first prints.
Richard Tymko
Active Member
I have a Prusa MK3. Ordered it as a kit and assembled. Great Great machine. Only issue I have had with it was when I updated to the latest firmware. Downgraded to previous version and working like a charm. Added a raspberry Pi with a printed case attached to the frame with a camera.
Raspberry pi with camera excellent! Very interesting. Can you control the printer at all or just observe it? Let’s see some pictures. Was it a kit? Your design?
Richard Tymko
Active Member
I use the pi flashed with astroprint. It worked better for me then octoprint. I can observe and control from anywhere I’m connected to the internet. I bought the pi3 as a kit. Camera separate and an extra long ribbon cable for the camera. The case for the pi I got off thingiverse and I designed my own camera mount. I’ll take pictures tomorrow..
kevin.decelles
I don't often print unattended as I've had some prints come loose on the bed and make a mess. My uncle-n-law has the same printer as me and has done the Pi /camera to monitor and loves it (enables watching Netflix from the couch and watching print in iPad
Lots of open source options , many integrated options . We use repetier as our frond end
thriller007
I’m just getting started and I have the flash forge adventurer 3. Just printing some axa quick change holder mount for the wall.
update...that worked good. Time to print a few more
