2.2 KW VFD, $70.39, Fullfilled by Amazon.ca
John Conroy
member
Yes I mounted the original Power on/off switch from the drill press front panel in a 4" X 4" X2" box. It is a DPDT switch so it works for 240 volt.
The green "run" and red "stop" buttons start and stop the spindle. The display is active whenever the vfd is powered.
Do you have the capability now to reverse the drill press with the vfd switch?
Does this VFD allow for inputting reference HZ to RPM conversion values thus allowing RPM to be displayed?
No mind doesn't allow for that. The Amazon advert for yours seemed to indicate RPM was one of the display options.
Oh then I'm probably wrong. And then I also have two hall sensors that I didn't need.
John Conroy
member
DPitman, yes it can be reversed. You can select direction with the FWD/REV key. In the first pic you can see the fwd LED is illuminated above the frequency display and in the second pic the rev LED is lit. You don't need to press stop before changing directions. There is a short video at this link.
https://johnconroy.smugmug.com/-Craftex-Drill-press/n-2tszPn/i-H9s87fv/A
Craig, it may have the ability to convert frequency to rpm but I couldn't use that feature because I am using miltiple pulley ratios so I never tried to learn how to set that up.
DavidR8
Scrap maker
Ordered one. Just because.
It’s will either be for my surface grinder coolant pump or a lathe conversion.
Some one post a link to this $55 VFD please. It's not the one I originally posted.
