Maybe he doesn't like the view from google earth....i dunno.What the heck was his problem?
@Susquatch - that’s when your f’n s’t F:/k municipality steps in and dictates that your max shop is 750 sqft and you cannot build bigger on 2 acres because it would be an eyesore to a bunch of dumb Fcks that are really pieces of fecal matter flung at a fan.
The story is here somewhere but my neighbour, good guy - has 4 shops because some piece of sndndt woman needed her VIEW. Her view was his back yard / many many many bad feelings - Well - 2 of the shops block her view now and he cuts down the tree growing so she always sees it.
Argh!!
I will need to pick up a new tool post,
You and me both.I prefer organized chaos.
@Susquatch : I had to borrow the tool post off of the imperial lathe (AXA piston type) as the tool post that came with Miss Metric sits low and you would need to shim each cutter. (It is a 4 tool rotary type) Also it is not a dovetail type holder so I could not exchange tools easily.
@dfloen : I know Darren, 3 inches of pink steel was my typical. I gave her 5 to see if things were going to work out (go big or go home). It worked great! Next is to see how she rides 12 Inches between centres and check out her tail stock.
No - just the one for the imperial lathe
@dfloen : she took the twelve inches in style:
After a preliminary cut and then moving the tailstock I was able to dial things in to no real measurable difference over the length of the rod. Pretty slick!
That is done quite often.I've been thinking again..... I know, I shouldn't do that.....
Why couldn't a fellow make an alignment bar out of a piece of black pipe and add replaceable aluminium collars at both ends?
This would make end cuts a piece of cake and still make for easy measurement.....
