10” Utilathe (Miss Metric) Overhaul Repair
So electric work is complete for now. Still may add the switch back for a task light and not sure on the push buttons - a coolant pump would be nice but it is messy as all get out and so who knows…..
Made the lever for the FWD/REV and finished up hooking in the VFD and everything is running. Chips - not yet
The ball is from Amazon - 5 for $20 and they have a brass insert for the threads. 3/8”-16 thread aluminum shaft.
Had a chunk of aluminum stock and turned it down to 1-1/4” about 1-3/4” long and cut a 30 degree landing for the handle:
Parting off the piece (for @ShawnR ) held nice and close to the chuck with lathe at 50 RPM and cutter 90° to the face. Moderate cross feed speed and spritz with WD40. Keep chips cleared
No “Yahtzee” or any special comments - basically happy. Put the part in the mill and drilled and tapped for the handle and a set screw.
The VFD:
It is actual right side up - picture flipped. Anyway it is in the cabinet and should be fine. The cabinet is pretty spacious.
Back of the cabinet is nice and clean. Just the power and motor cable.
Space between the lathes will become storage for stock- I will make up a rack with some slides perhaps.
Top view:
The reason I haven’t made any chips is that the tool post supplied need some trimming to work on this lathe. It holds the bits all 1/8” high. I only have a few carbide insert holders and all of them sit to high - alas. I can “borrow” the one from Mr Imperial
Why does my nose feel like it just got rubbed ?...:rolleyes:
Not sure who I am happier for ...you or @justindavidow .... both looking at new equipment up and running in the shop this week!
@YYCHM those are the original doors. The Opel is butt naked and just needs the old engine dropped and suspension. Engine parts came and a new block is going in with about 20 more HP.
My attic in the shop is pretty full with parts, glass, etc etc
Then we have the welding project. @Susquatch if I do not burn a 11 pounder I will be cheating the car - LOL.
New sexy pistons
Should be fun - plus we have a couple boxes of all new parts to keep the boss comfortable- like seats, carpet, heater core et etc
@David_R8 - the main shop - detached is 750 sqft and then I have the garage - 480 sqft. My super wife has given her parking space in the garage up for the Opel restoration project.
The main shop has all the cabinet making stuff, 2 metal lathes and the mill and the tooling for those. The one side of the garage is partitioned so that has the tool sharpener, tooling for that- a work bench, cabinets and the welding station - welding table (mobile) and the parts clean up - more storage.
I have a baby barn that is 8x 10 with a loft and it has the wood storage, some steel, second tractor and car stuff/gardening ?? Shovels etc and a rack for framing nails, roofing etc.
Thinking on another out building for the HVAC company stuff, the one tractor and maybe a spray booth section - who knows lots of dreams hahaha
@Susquatch - that’s when your f’n s’t F:/k municipality steps in and dictates that your max shop is 750 sqft and you cannot build bigger on 2 acres because it would be an eyesore to a bunch of dumb F:)cks that are really pieces of fecal matter flung at a fan.
The story is here somewhere but my neighbour, good guy - has 4 shops because some piece of sndndt woman needed her VIEW. Her view was his back yard / many many many bad feelings - Well - 2 of the shops block her view now and he cuts down the tree growing so she always sees it.
Argh!!
Thread hijack follows, apologies in advance.
Years back I went to my local planning dept to get a permit to build a 12'x16' (192 sq ft) outbuilding on my city lot.
To get a permit I had to submit architectural plans and pull permits for electrical (and plumbing if I was going to have running water inside)
Even though I was building on the foundation of the single garage that was on the survey they had.
Long story made somewhat short I looked at the bylaws and saw there was no limit to the number of "accessory buildings" so long as each was under 100 sq ft.
So I built two 8'x12' accessory buildings. Right smack dab next to each other, so close in fact that for safety reasons I had to bolt them together. :)
When I sold the house not a word was said.
<hijackoff/>
Argh!!
Weird, I was just talking to a friend a few counties over who encountered a similar bi-law. He bought a place with 5 acres specifically so he could build a nice pole barn. Nobody told him there was a bi-law against it. They wouldn't even entertain an exemption. Man is he ever pissed!
