What's Paul up to?
Shear mounted. Stable.
The only fly in the ointment is that the whole bench is 4" too tall for me. I'm going to have to take 4 or so inches off the legs and the only way I see to do it is slow-and-steady with an angle grinder and a cut-off wheel.
I'm going to sleep on it a few times before starting down that path.
Put a 4" high wood platform in front of the bench to stand on.....
And my cheap VFD on the power hammer has died. Probably from trying to run a 2.2KW motor on a 2.2KW VFD. I've moved a cheap 4KW VFD onto it to keep running while I see if Vevor will honour their 1 year warrantee. They are quite responsive on their support email, though their first reflex was to offer me $20 to go away ;-). I can tell this will be one of those "negotiating with China" projects.
Yesterday was a barge day:
AIL4fc8j-BaeQdnUK2v3eHvod3ZwtgYK7cBdD-8TU-27RozODXCX_LW3u4TE9ZWmSdMSk2RtU6rHJrsHNQmC9DOOk5mNTF-97Ilg2lr1we8phpc_inpAbZIvYVUte7UIeLT4wQEmSvXrwfAINnrf4jzUR6Z0TronkDfeduFlZgVoYAqOhVDCVPy9gzUV7XatlYIpnm6-pbXZ9-XcPPcYi18g6Hy_w7VCcAOxlF-381XK4DWAjav35ixIdELFQcz7mZgIXggX6r2N0j_PDdy_A0tan69qZniaUHJfq6tCCC2ws7k2jkhiMYkN-puIasc85AZ0SpbMb1MjZINV9aTYASlXa_Hl7MIJIO0zgeb7C35l03mvF5XnCW_VVjpHkSvQCHmESWGbnRlR2cseXVJKKWAbY7ReJtu-NN6emsz-NVIu_05dXLly1uegSRTTrnhFSAyZEsT-frYjHUHfHF-UnUoMI6NaRlEEqH7TVPhhspnBN6bHIAXl5B_NGPsBna_YiiUSMS0OlYVQSr8ng4Ba-jyMQ0zT2DyWYPl9ysr11AVLZirGcHu-eZNfoKmHb658bNCwFeCJv3gQyD7zsznbf6FidDfkRDkV_gc-DdRUIeN9fbr129rXfGMOz5w7iyM8jWuTwr1XhrFUJVphTOgYT6pS4RP4ZfjJN5S-QEIMJKyy-w2OJ8ltITImige7hdGlJsSsDd7hAAalXAqBB17HEmkSx17ylC--M_4QRe9t4Ol0gURfNHmnh9fAKegkA8Olh7LHPG9IUb2riTyvY-tUkedwu2LbmKBqj9iKi2kO3hTXQEuCZU2bCF_P0_Uab6uMfPUdhydxDguLL57S25nQM-u-4lMWfAkKRCnP7repsSyIblYbB-Azvb_PbGdH_KrqL3mESqOdKALoeEchczbso7zH730=w772-h1025-s-no
This little unit is replacing the gas-guzzling F150 I have at the cabin. Electric, 1000lbs capacity dumper, 1500lbs towing capacity, 50km range on a 5 hour 15amp 110V charge. It also has a solar panel on top to reduce reliance on that plug-in. For our <10km/week typical usage we should be fine.
The forward hitch receiver was *really* useful getting the trailer onto the barge.
The second fun part is the trailer's load of goodies for the smithy.
AIL4fc-uIyqnQnbS6SJ2LpIZDEMASUMbUUD0KeyxLQrecmJIcLWVQEq0LSqW_Vz2eVsjQ6ZAyldD-Uc0rylQII60B3CXP64x5D-_YaQg3LHn7gkiBnqlfdLew5_Kjm30zr5a90WqzskoDg6Gzl6H2cO06Jt-c9QFbimoeUe7HsdO7iXaLecFTJXtohbawxaS1Z__8bCn5R6Ys45MecexsDlUud3-pfFsnxxqGtYE-4LAaIxr3pNJsLh4-CN5FGTMAp1nG6dZ6U8Sn8-4VFOvnyadoVFwho7Y7KKOTVFfB3aPwLf37-rxZY9ZJBMWXEJ6Mk79GUXTYuTiSr-gS-ma6SM-7zlwrpJJhYH8eDupPsHo6Gq8mFIVsSg6gXstKNJSPBi3oCC_cjWA_cTmnT73JgBZcmlrXzPwplt2hFhKMdCLJdm3_B9mi_VB5N-5RdU-_0s_Pej-VAnIx340JB7786i858UOKYI3-9VOrLTsuzIJt5sdZy9ds_LtfDeG-8TkUA-iFxx0qSAAt6XO7Pnyz4EOe2th_eXslbapyCSaF1JHIWXD_r-cMSgsDlXeaTu11XeUzhy49VxaMj2JlXZdJ45GL5k5clcCeAh-L3WNKo2PwVJiu__AIfZBkTL9NqFDcITZPQ_6WlS5YhZjl9ebyO6ara2ImU7M9_60Jey_7VmSnladWHLgGRbBJGefP4SjH_qARcnn11IyLXYQQdvpKimTc_wdUJYyB2uEqrE9cQGvZd5-m3PiqwqC3KTnVXaIJla6BmQ98YTny6dzQ3LtisR-4cZu2M-CIg3tvEHFLMaQptkHdFYBKQ6aKhEUOU2VqRMQTZG0iumuVXvTEAdHIsIjQLX9MKz-0LiBK-TO73k_d6gBnLWiFBjJlPZ0drPmik39nIyRId6NmGr8Q6WNEos4-h0=w772-h1025-s-no
That's the drill press my grandfather gave me in 1991 before heading west. Behind it is a 1908 cabinet-maker's toolchest that came over with an acquaintance's great-grandfather after his apprentiship in Scotland. It hadn't been too raided over for tools when I got it, which set me up with a set of hollows and rounds, a full set of brace bits (spoon-style), plough plane, wooden clamps, wood taps and dies, and a few other goodies. Behind that is a friend's dis-used horizontal bandsaw - a Brico 4x6. Very much as crappy as the King I have in my city shop, but now I can cut stock here in the smithy as well.
And invisible is the last important piece - the new firepot from John Newman Pattern and Forge. It's a monster. Yes it shipped "loose" in a cardboard box. Yes, it arrived in exactly as many pieces as it left in.
And in case you wondered if these pots are durable:
Yes. It's at least 1 1/8"th thick everywhere I poked it. More like 1 3/16"ths. I expect it will see me out.
That's a good looking unit. The front hitch makes parking the trailer so much easier. I made a bucket mount hitch for the tractor a rarely pull the trailer any more.
Oh, nice additions to the tool collection as well.
I am thinking of modifying my loader bucket to accept a ball. But I haven't started the actual reading/thinking.
So many projects.
@YotaBota, @PaulL @jcdammeyer
Princess Auto sells a 2" hitch receiver that you can bolt to your bucket without welding plates. I drilled holes on the right, left, & center of my bucket to take it.
I use it for everything including my travel trailer. Guys like @Chicken lights & @140mower can prolly back a trailer into a spot with 1/4" clearance, but I can't. I need at least an inch LOL! Using a loader bucket is SOOOO easy. Well worth bolting on a receiver.
I keep in on a shelf and only bolt it on when needed. I don't even use a wrench. It's solid without because of the bending load.
No cranking on lift Jack's, just drive up, lift the bucket, and go.
I also have a three point hitch I use when I need to pull instead of push.
I'll take photos later today.
Here is another gizmo every guy with a loader tractor needs. Bolt-on chain hooks.
Robbor Grab Hook 5/16 in Bolt-on Grab Hook Grade 70 Forged Steel Tow Hook Work Well for Tractor Bucket, RV, UTV,Truck with Backer Plate and Hardware -2 PK https://a.co/d/awwi4ui
Lots of different options for such things. I put D-Ring plates on the back plate instead of a plain plate.
Just drill holes where you need them and move them as needed. I put two on the back of my bucket permanently. That's where the hydraulic leverage is highest and I seem to use hooks the most.
