That's why we went with the retro-fit, cost more but fast, easy and no outside help needed.
Just curious, we just replaced the bulbs with the equivalent dimmable LED bulb. Same look and no installation.
Why change the fixture?
D 😎
I tried replacement bulbs, but something about these cans has them running hot and failing early. I gave up.Just curious, we just replaced the bulbs with the equivalent dimmable LED bulb. Same look and no installation.
D 😎
Was much easier to pay someone to deliver and put it up. Didn't cost that much more than just getting the board delivered. Two guys walked in and they were done in 3 hours.Nice work on your shop btw.
Very smart idea with the plywood. You will enjoy the 10' cieling.
Are you going to fill the drywall yourself?
Perfect opportunity to take those pictures you forgot. 🙄😛It's been a really busy start of the year with very little shop time - most of it has been going into the kitchen renovation. But there are a few wins this week.
First, chimney is finally up for the forge. I had to make up a collar to support the chimney against the roof purlins. It's a simple band with two clips welded to it and tapped to accept set screws. Those clips rest on angle iron that spans the purlins. By bolting one end of each in place the placement of the other end sets the side to side plumbness of the chimney, and the clips and set screws set the fore and aft. No, I didn't get any closeups because I flat out forgot. It's a long way up there.
View attachment 61009View attachment 61010
Second, the kitchen renovation did me a favor. We've decided to dump the propane stove in favour of induction. And the cooktop is a bit of a beast - it wants 7.4KW, which is just on the edge of what the solar inverter could provide. So I used the kitchen renovation as the opportunity to add a second Sol-Ark inverter to the setup and we now have 75 amp service! I should have done this two years ago. 2HP single-phase motors now start without a hitch. My welder doesn't cause the inverter to shut down at high power. And my induction forge can now pull full power! Oh, and we'll have a nice induction cooktop too.
Third, my 1898 vintage Reynolds bandsaw is up and "running". Which is to say, I have a 2HP motor running at 1725RPM and some v-belt running on top of the 10" flat belt drive pulley. Not great traction, but enough to do light cuts. Resaw work awaits a larger motor and some flat belts belts. Jack Forsberg is helping me out on the belts side and I've dropped a request under "Classified" to see if anyone can help me with a motor.
I also made up some nice blade guards for it. I'd been running plywood abominations for a long time and I happend to have some nice 12ga in an L profile left over from the workshop construction. Those look much better. I even painted them! Who would have thought that black-on-black photography would be difficult?
View attachment 61013View attachment 61014
Anyhow, first fire in the new chimney setup will be this afternoon, as soon as I cut around the insulation that I realize I left rubbing against the double-walled portion. Unlikely to cause grief, but I'll clear it an inch away as it should be.
They didn't. But I did ;-)What a beautiful saw, I didn't know they had cresent wenches in 1898.
Yeah. Kitchens have changed. Nowadays you need a designer who can generate the CAD to drive the CNC panel cutter/edge bander, and an installer who can scribe panels to your walls accurately. And then shell out a fortune to the quartz cutters.Looking great. I'm told I have a kitchen to do this year too....Been ducking it for years, but it's time.....
My previous kitchen in that space was Ikea, installed by yours truly. Didn't know enough to scribe it right, and I never liked the kicks, but if *lasted* and it was *cheap*. I mean, $6000 included the ceramic on steel double bowl farmhouse sink, which we're re-using, a gas range and range hood, and a $1200 store credit to fill the cupboards with.For the cost, Ikea wins. And its not cheaply made or all made in China either. Things like hinges from Italy, door fronts USA (ok, not happy about that anymore 🙁) and parts from other European countries that I can't remember. Also, as I was doing mine on the cheap a custom laminate countertop through Ikea was made locally and for less than I could do by calling around.
