Dan Dubeau
Thanks for the tip. Never thought about trapped air in that way, but you can bet I will now lol. Makes total sense. Not that it would matter for this, but good practices are never a bad thing to work into ones work habits.
That list is probably pretty long.... It's actually why I dragged it into the backyard closer to the hose, instead of doing it in the blacksmith shed lol.What could possibly go wrong?!?!
My usual answer to ‘What could go wrong?’ is ‘Do you want that in alphabetical order, or…?’That list is probably pretty long.... It's actually why I dragged it into the backyard closer to the hose, instead of doing it in the blacksmith shed lol.
A good try! I am wondering about the big burp, I had always used a sprue and a riser, wonder if a riser coming off the side might have helped. It appears there is a void on/in the side in 2 of the 3 last pictures. I can remember the riser sometimes appearing to vent when pouring before totality filling. My take on it was that the molten metal was flowing in though the sprue and pushing air/gases ahead of it and resisted allowing them to come back, therefore needing a way out. It maybe more so because of the coating on the foam not allowing venting through the sand.
Is the gray surface in a few pictures, the drywall compound still on the casting? I did a few lost foam casts many years ago, however none of foam was smoothed with wax or covered with anything.
Anyway a few thoughts, good or bad.
