Pattern all cured, i wanted to check it on the lathe again
Yep, should be able to get it all on the lathe. Still want to try the r8 arbor though.....
Next was to cut the spru. It DID get used....
Done. I'm going to try filling some holes and making some fillets with wax, and see if I can smooth it up a bit. Debating on the drywall compound coating. Some say it's not needed, others swear by it. If I don't use it, I can cast this today....if I do, it'll be next weekend probably.....
