Weiss VM32 CNC Conversion
More progress today. Basically have to disassemble the mill to install the ball screws.
First I made a drill guide to shift the mount holes in the casting.
That worked out well so I turned my attention to taking the head and the column off so I could install the Y and Z axis ball screws.
I don’t have pics of this as it was very difficult to do.
There’s a gas strut in the column which was a complete pain in the rear to remove because unlike gas struts on a trunk for example, the strut couldn’t be popped off the ball. So I had lean the column back so I could unscrew the lower ball about 1/16 of a turn at a time for the length of the 1” stud.
Once off I tried to slide the Y axis ball screw into place.
No dice as the base casting prevented the end from going all the way through the hole in the front of the base.
Break on the angle grinder and cut the opening an inch longer.
Dressed the new cut with a file and now the ball screw can slide into place.
With the ball screw in place I put on the mount which contains two bearings for the driven end of the ball screw.
Mount fits perfectly on the shaft but the hole in the front of the casting isn’t large enough for the ball screw to drop down enough for the mount to match my up with my newly drill holes in the casting.
Off to Home Depot to buy a 1.25” hole saw to enlarge the hole.
With the hole enlarged it was easy to put everything together.
On the Seig X3 mill it is possible to drive the table past the limits if you do not have limit switches or if a switch was to fail. Not sure if this would be an issue on your mill.
That's a good idea. Not sure if the ball nut coming off the end of the screw is a concern as the casting is about 3/8" from the end of the screw. I think the table will run into the column before it reaches the end of the screw.
More progress.
I needed to mill out a slot in the Y table for the x-axis ball nut.
Since my mill is in pieces, @PaulL came to the rescue.
His huge First mill makes mine look like a KitchenAid mixer! Very nice machine. I can see why there’s so much love for big machines.
Anywho, we got the slot milled out.
Double ball nut fits perfectly.
We had to mess around a bit with tooling to find something long enough to reach the slot so we could lengthen the slot for the M8 cap screws.
A counter bore makes a fine side mill if used carefully. Good thinking Paul.
The main challenge was standing the carriage up solidly:
Fortunately I had a 2-3-4 angle plate nice and square, and a second 2-3-4ish block I'd just finished squaring. Between the two we were able to sandwich the carriage between them and anchor it. We just had one poor moment in which the filling attempted to pull out of the sandwich, leading to a quick clamping change to move the right hand clamp over the dovetail edge and re-zero-finding the slot.
A productive morning, and a happy @DavidR8 . He can moderate the picture (and this sentence?) out of existence if he doesn't like it ;-)
Hoping folks can check my thinking.
The X axis ball screw that came in the kit I bought is too long for my table so I need to cut it down and machine the end.
I don't want to mess this up.
Here's some pics to illustrate the situation.
Here the excess length and the machined end.
This is the bearing carrier and the mount that bolts onto the end of the table.
I measured the distance between the end of the table and the mount and came up with 130mm.
This is what 130mm looks like on the ball screw.
So my thinking is if I cut off 130mm of length then machine then machine the features on the end, the mount should bolt up to the table. For good measure I may make the bearing surface a smidge longer to make sure the mount seats well on the end of the table.
Is my thinking correct or am I overlooking something obvious?
Most pre-machined ball screws have the other end machined with a snap ring groove, might be easier to machine the other end. The outer skin of the metal is hard but the interior is relatively softer. Have machined quite a few for our mini-mills.
It’s similar to machining IHC or chrome plated materials. That first cut ideally is such that you get ‘under’ the outer skin. In a pinch some grinding to get rid of the bulk of the hard stuff first may be easier if you have a small/light machine to do this with.
Dave, it looks good to me.
Just to confirm, your stepper (servo) is on the left side of the table? The right side is just the support for the non driven side of the ball screw?
How do they secure the ballscrew on the right side?
Unfortunately, the other end end has a threaded end for a nut. So this end seems like the easier one to modify.
My plan was to heat the area where the cut needs to be made and back where the features need to be machined.
