I'd like to order a spare wheel or two, just in case for the future.
Can you shim the back of the wheel to move it out? I guess that would only work if you can get the arbor loose.I am still waiting for support back from VEVOR. When I look at the drill bits that @DavidR8 did compared to mine it looks like the wheel is not in the correct position. I sent this photo to VEVOR showing how the split grinding on one that David did doesn't touch the edge of the wheel. There's nothing I can adjust to make it come closer.
I can't turn it any further because the pins prevent that. They said they'd respond within 48 hours. Not quite there yet. And I even bought an extra year of warranty for the darn thing.
The set screws on that arbour must be thread locked and I can't grip the wheel well enough to twist the center screw that holds the fan in place.
@CWret that's the first 1/2" bit that I sharpened on my MRCM-13A sharpener. I gave it to @jcdammeyer to see if his machine would meet the bit placement on the split point op.
@CWret that's a 1/2" bit that I sharpened on my MRCM-13A sharpener. I gave it to @jcdammeyer to see if his machine would meet the bit placement on the split point op.
John can elaborate but getting the wheel off was a no-go.
That's why I haven't tried super hard to take the wheel off. If I break it I'm not sure it's covered by warranty. I'm hoping they will think it's the wheel and will send me a new one. Then I can try the shim stuff and have a spare wheel.In that case, rather than risk damaging it, I'd want to exchange the whole grinder.
Those are really good questions. Since it was removed from David's holder the chance of getting it exact is not very likely. So what I did was set it in the arbour loosely (but still held straight) and then with it held against the front pin, I twisted the drill bit so the back relief fit perfectly against wheel. There's the gap.What is the diameter of the bit in your picture?
The little gap (pointed out in the pic below) is confusing. It seems that the bit is not at the right distance/location from the motor. (too far away). This would be an unexpected manufacturing problem. The grinder seems solid and well built. But even with this apparent inconsistency, it should still give a vertical edge on the split point - but your other pictures showed a rounded edge at the inside of the split point.
Did you have the bit correctly clamped in the chuck? Did you review (use) the method of installing the bit it the chuck as was described in the link above? The bit cutting edges must be parallel to the edges on the chuck.
I assume you did install the bit correctly in the chuck and therefore it will be very interesting to hear Vevor’s response to your question.
One option is to pester @DavidR8 again but mount the drill bit in my holder, have him sharpen it and add the back relief and split point. Then take it home still firmly clamped and see how it fits against my wheel.Those are really good questions. Since it was removed from David's holder the chance of getting it exact is not very likely. So what I did was set it in the arbour loosely (but still held straight) and then with it held against the front pin, I twisted the drill bit so the back relief fit perfectly against wheel. There's the gap.
Now if I do the opposite and turn the drill bit clockwise so the gap is filled the back relief is way off the stone.
To me it looks like the wheel is too far back.
Happy to do that John!One option is to pester @DavidR8 again but mount the drill bit in my holder, have him sharpen it and add the back relief and split point. Then take it home still firmly clamped and see how it fits against my wheel.
^ that sounds like a good idea to zero in on the problem and determine if it is the grinder or the way the bit is being clamped in the chuck.One option is to pester @DavidR8 again but mount the drill bit in my holder, have him sharpen it and add the back relief and split point. Then take it home still firmly clamped and see how it fits against my wheel.
that needs to be shimmed to the left instead of shimming (or moving) the grinding wheel to the right. Adjusting this bracket might be easier than trying to change the motor/wheel geometry (also messing with the wheel location could adversely affect the grind on the bit face.
