Machine Vevor MR13A/B Drill Bit Grinder Users
Machine
Web thinning is done on the back hole and the front hole splits the point.
That's very odd. Which way is the wheel oriented - smaller OD out or in? And which hole is furthest out - the front hole or the back one?
Well that, plus your earlier photos settle it.
I don't know how they do that without adjustments beyond the rear sliding block. Perhaps by the time they developed the D model they had all that worked out.
It's a very nice grinder that is many times better than what it costs compared to other Sharpeners.
Very nice. I see that it does both web thinning and split point. But I don't see a mechanism for adjusting it other than sliding the entire top block sideways. That seems odd to me. Is there more to it than what we can see in your photos?
They're effectively giving you depth adjustment by moving the holes closer and further from the wheel axis. To adjust it, you need to adjust for the closest hole first, and then adjust the rear one. That's fine if everything is going to stay in place long term.. but the issue is you cant adjust the front without effecting the rear. Also if you ever need to remove that top plate you would loose all your adjustments as there are no dowels or match marks.
I found my drill angle sharpening was great right out of the box, as everyone's seems to be, but the upper holes were not doing much so I've started adjusting.
I was also surprised that the D was not just a combination of the A and B w/pivots, like that Motom (Sp?) brand one is, but is a unique design. I think it's a cost thrifted design, but seems workable.
I think you are right. I hadn't caught this nuance but that makes perfect sense.
If I may, what did you pay for it and where was the sale?
I can't wait to hear what you learn!
I was going to buy the A model, but I found the D for $330.90 on vevor.ca and I found a coupon code that worked. Looks like the sale is over. I was also amazed by the shipping speed. I ordered it at 11:30am one day, and received it by 10am the next day.
Order Summary
Subtotal: C $330.90
Shipping Fee: C $0.00
Coupon: C ($26.48)
Total before Tax: C $304.42
Estimated GST/HST: C $39.58
Grand Total: C $344.00
Nice!
Where are you?
I've ordered a lot directly from Vevor too. Their reward points are like coccaine. Gotta use em. Gotta go to Vevor to get em.
Everything is great at Vevor until its not. I recently bought 2 items that were not as described. I complained and they gave me some cash back to offset my pain. Because the items were not "defective", they would not do a free return refund. I had to pay return shipping. That was gunna be a fortune. So I took their cash back instead. Both amounted to about 50% of purchase price.
Hint - never accept their first offer. Counter with something more reasonable. They usually agree.
It would have been painless on Amazon. I've found that Vevor will provide support (including partial refunds) even for items purchased from Amazon.
Maybe one day I just bought new dusk to dawn security lights for the garage alleyway there sure isn’t much of a choice of models and of course I couldn’t find the same ones as before.
OK, add me to the list MR-20G owner now. Figured go big or go home - I tend to break small bits so only have the bigger ones left to sharpen!
Now to learn to use it, basic sharpening seems ok, but the web thinning seems off - cuts into one side of the drill only. It could be the 3/4" MT3 drill I'm using - it looks like it was forged (!) so might be less than straight, I'll try another drill before I mess with the machines settings.
what did you pay and where did you buy from?
Practice a bit with various size drills. If you find it's consistently wrong then something is out of adjustment. I had to do a lot of work to get mine to work correctly. Somewhere there's a thread on that.
Unless you are doing something wrong, that will be caused by a drill that is off-center. I'd bet on the latter. I find it pretty common for old or crappy drills to be off center. High quality drills won't do that.
I liked my 13A so much that I caved and upgraded to the MR-G3.
Currently still have the 13A, but it's on long term loan to a friend. G3 covers the entire range of the 13A, but has a second collet/grinding setup to use ER40 collets, so it can grind up to 32 mm drill bits.
