In anticipation, I drew this mag drill plate or 'shoe' for clamping. I'm thinking this could be 3/8" plate and you stick the drill on it, turn on the magnet, then position the drill where you want. Clamp down the wings as required to hold it all in place. Put some teflon tape on the bottom to make it easier to slide around. Then you can drill other materials besides steel like aluminum, wood, door frames, thin steel sheet which Susquatch says does not grip well....
