Joe got back to me. He cobbled it from an old mobility cart that was rotting in his driveway. Uses a 24V motor and variable speed controller complete with 24V charger and 2 old 12V car batteries. The drive unit was fabbed from the cart drive trainThis is the approach my friend Joe used for his powered knee. He had various pulleys, belts, sprockets and chain in his junk pile. I think he's using a 12V battery charger to run it. I've asked and when I find out I'll post the info.
That's why that one Arduino based stepper driver looked so interesting. It uses what's called SPI to set all the parameters and I believe the direction but it can take step pulses in for the actual motion. Looking at the data sheet for actual chip I couldn't find an external direction input so adapting the driver to MACH, LinuxCNC or one of the other CNC programs would be likely more difficult.Several guys on youtube have adapted stepper motors and their controllers to be a power feed. they really aren't rocket science, just a pain to adapt.
I can afford the 1" of X-axis travel (he says now...........). ill try it....It definitely sticks out less than the horizontal style but it will likely remove about an inch of X axis travel.
Thanks. ill try to get some pics.......astill madly reading and trying to decide on magnetic or glass scales for the DRO![]()
Lots of pros and cons: magnetic are so easy/safely to shorten, was the big + that did it for me.
I think these are capacitance scales. They are harder to find nowadays. I have this Shumatech DRO-350 (and a spare in the box) on my mill and it was designed to work with these types of Chinese scale protocols clk/data. The later DRO-550 (I have two of those not in use) could also work with quadrature type while the DRO-350 needed an add on board to convert quadrature to the Chinese protocol.Magnetic is my choice.
Or build the scale combiner as shown in the attached schematic. I'd have to look at the DRO-550 to see if it can handle 4 clk/data scales directly.
So much has happened in 20 years. Back then if you wanted a scale for mill it had to be glass. Then suddenly we had the caliper type scales and the Shumatech showed up. And finally the rest of the world caught up and now there is quite the selection and finding scales like the ones I have is harder. Who would have thought you could glue down a strip and move a sensor along that. So cool.@MikeANW - pretty much all the latest commercial units out there include combining scales. I know for absolute certain that Ditron and TouchDRO do. For example, if you buy a 4 axis ditron or touch, you can put the knee on one axis and the quill on another and then tell it to add the knee and the quill to display total Z. My Ditron is setup that way and I love it!
Mine has arrived. Ill see what it will take to fit it this weekend.....has anyone tried to mount one of these on the Z-Axis (not the Quill)?A BP style PF can be adapted. They are far more common and less expensive (less than $200 from VEVOR) than the horizontal models.
Both @David_R8 and myself did this.
Vevor PAI-310S. $189.99What did you get, from where and for how much?
Morning everyone;Keep us posted with this project - looking fwd to seeing completed install.
