Starrett Stuff
thestelster
I picked up some used Starrett goodies today. As well as a Mitutoyo small hole gauge, mint. And probably one of the first indicators, before DI's, and DTI's. This one is by Ideal Tool Company.
The other day I cleaned up the Starrett #454 E&M height gauge, and made a bent leg holder to hold DTI's and DI's in line with the beam. I modified a Starrett snug that I had so that it would fit the holder. So now I can use an indicator with either a 3/8" shaft, or the dovetail.
I'm still waiting for the scrbier carrier to hold my holder onto the height gauge arm.
I found a bunch of height gauge pieces on Ebay, bid on and won. They just came in. I just have to clean them up a bit. Only 2 of the scribers are a direct fit, the Starrett and the Brown & Sharpe. And two of the scriber clamps are Starrett, but one is missing the little flat spring.
With the z-scriber, I have to subtract 2.000" from the reading to get the actual height below the scriber. This way you can measure low heights. By using a straight scriber, I can read it directly for heights taller than about 1.4".
And I can use the DTI for height comparison.
Oh, and a squareness comparator too!
Nice score!
I've wanted one of these for a long time. Starrett #220, in really nice condition.
I have an older Mitutoyo just like it with a Vernier 10ths scale on the barrel. It's a beautiful micrometer. I can easily understand why you have wanted one.
I use mine mostly with the gauge pin for tubing thickness. In my case, mostly to measure brass case neck thickness at various depths.
I guess I'm a Starrett fan-boy!! (Except for digital calipers which are Mitutoyo).
LOL! Starrett makes good stuff too!
Perfect unit for most chambering other than the odd 20tpi.
I forgot what thread tpi your other mics cover.
My Metrology tools span the waterfront. Some top notch, a lot in between, some cheap stuff that actually works, and some junk I should never have bought.
Just received a 12" Vincen digital caliper with inches, metric, and fractions. My 6" Vincen works well and I wanted a 12" caliper but wasn't willing to pay for a Mitutoyo. So I opted for another Vincen. Time will tell.
I have a Mitutoyo interchangeable anvil 0-1" thread mic, but I need a couple more of the anvils. But they cost $85.00 per thread pair!! And of course, because its 0-1", it's too small to measure any barrel threads.
I've heard that their products have gone down hill for a number years. But their older stuff has always been top notch. That's why I keep looking for a good deal.
Yup, I'm a Starrett fan-boy!!
Good stuff Stel! Love it!
I think you already know that I bought the Accusize thread mics in 0-1, 1-2, & 2-3 so they work on barrel tenons too. I'm quite happy with them but I seem to recall that you were not too thrilled for some reason......
Almost anything has to be better than thread wires......
I bought a couple of used Starrett #568 v-blocks today. Unfortunately, no clamps. They're a matched pair. So I quickly cleaned them up a bit and went about measuring them. Less than 1/2 a tenth of a thou' square and parallel on the one, and 1 tenth on the other!! But the v-surfaces have a couple of depressions on them which looks like a shaft was rotating in the V. So I might have to investigate how to properly grind the v's.
No way! Those Starrett Tap Wrenches are GORGEOUS. Wish I never ever bought anything else. They are like 10x the, quality and functionality of their closest competitor. I have all of them now except their very biggest 91E - their phantom model. Some say it used to exist, some say it never did. I can do without that one till I find a deal I can't refuse. LOL!
Hey, do me a favour at your convenience. Grab your 91B tap handle and let me know if it will hold a chamber reamer by it's square section, and measure the thickness of the body please.
