I’d probably go with just the gasket glue, very thin. On old machinery you can go to town on gaskets, but with precision fits it can interfere if too thick in my experience,
The reservoir seems to connect to both sides and there is this little hole the oil comes out and up through the bearing cover - that square slot and into the bearing. So the one sight glass covers the whole thing. That empty hole to the right you pointed out earlier Rudy is the drain cock. I guess it does not take much oil at all.Any conditions associated with the 24h cure time like temp, humidity, etc?
Question: how is the bearing oil retained if you have a “dry” HS? Is there a reservoir of sorts for each of them and individual sight glasses for observation of the level?
I was astounded. I certainly didn't spend that much!OMG that's pricey!
congrats on the reassembly - go John!
While still a reasonably pricy lathe, in 2000 the Australian dollar was as low as about $0.50 USD.OMG that's pricey!
