Good to see you getting back to the project!
That is the rotary tool holder. Holds 8 tools. It’s motorized and spins each tool into position automatically. I still have to figure out the calibration for it. I can manually spin the tool into a close position and then use a straight edge to dial it in to centre.What is this thing with all the carbide tooling in it......?
I believe the mechanism is very similar to a rotary table. Worm gear?Amazing that such a "quick change" tool holder has enough rigidity to actually work! I would think the cranking gears take one heck of a beating! I'd there a locking lug of some kind?
There is another fix for that @Tom O. In the setup for the haas post checkmark G0 for rapids. below... But perhaps that is only available if you subscribe?Same as the Haas then I have to change the feed rate from 650 to 400 for the program to work using fusion 360.
Ya but rotary tables have a lock. Mine has two. To work with a motor drive like that, that thing can't have a lock. All the force will have to be reacted by the gear. I think it's a lot to ask of it.
