Your right but i just looked outside & no cows yet...so..
Not convinced pressure variance is at play here as equal distance hole spacing for 360 deg should have essentially an equal pressure at the exact same time for wherever the slug is in its travel through the brake. The bore was out beyond the table edge so back pressure between table & bore is non existent ( along with the surmising that the slug would have long excited the bore before the blast force returned from the table to bounce the barrel) .
With no sophisticated testing equipment to be had we had to more or less theoretically remove each possible scenario until we were left with the one remaining possibility that we could not overrule, that being that the bore could not be directed downwards at all by the upwards direction of muzzle blast out of the top holes & sideways movement was slowed by front stock friction between it and the bench rest long enough for the slug to exit the bore. These and one other realization that happened convinced us...When we only had holes through the top and sides of the brake we had no more fliers.
Again, I'm just providing my thoughts on this for whatever they are worth to you. If that is zero, I take no offense. Sometimes we must accept the results we get whether or not we fully understand why.
In trying to visualize my thinking on this, try not to think about combustion gases venting out of selected holes or symmetric holes. In fact, try not to think about gases venting at all. Instead try to think about this gas as though it were standing still but vibrating with entrained sound pressure waves. More or less the same concept as an AM radio signal carried by a radio frequency signal. In reality, the gases are moving and venting, but they also carry pressure waves within the gas that bounce around in there much much faster than the gases themselves. And because the gas is so highly compressed and dense, these waves travel through the combustion gases much much faster than the speed of sound and much much much faster than the speed of the gas itself.
If you are familiar with the OBT (Optimum Barrel Time) theory of how accuracy nodes arise, you will understand that barrel vibrations caused by charge detonation travel up and down the barrel faster than the projectile does and that these vibrations (not the same as barrel whip) affect the projectile's internal ballistics. Mind you, despite its very widespread adoption, I don't buy the OBT theory in total. I think there is a lot more to it than that. But nonetheless, the principles are similar enough to be worthy of the comparison.
I am only "suggesting" that these
density waves (not the gas movement itself) that are inside the gases themselves reflecting off of various surfaces could cause various things to happen and that they could be both bad and good depending on their precise timing, direction, and consistency.
All things being equal, I am a very firm believer in consistency - everything and anything that could have an effect should be controlled as consistently as possible for the best results. Hence my position that the axis of the brake ID should be concentric to the axis of the bore.
I totally understand and accept your findings about the brakes affect on the target results. This is quite similar to the difference between constrained and unconstrained recoil. The difference matters and your results show that.
Anyway, it's just my thinking on the matter. You didn't seem to understand what I meant about the difference between gas pressure and pressure waves within the gas so I thought it might be worth an explanation.
