  • Several Regions have held meetups already, but others are being planned or are evaluating the interest. The Ontario GTA West area meetup is planned for Saturday April 26th at Greasemonkeys shop in Aylmer Ontario. If you are interested and haven’t signed up yet, click here! Arbutus has also explored interest in a Fraser Valley meetup but it seems members either missed his thread or had other plans. Let him know if you are interested in a meetup later in the year by posting here! Slowpoke is trying to pull together an Ottawa area meetup later this summer. No date has been selected yet, so let him know if you are interested
  • Home
  • Forums
  • Buy and Sell, Deals Spotted, and Help Required
  • Member Spotted Deals
RF45 too good to be true!
I don't know but the whole thing sure looks like a scam. I did a search on Ali for " ZAY7045FG mill drill" and it turned out quite a few but prices are way off the one advertized. From$427 to $4732 + $1500 shipping oh and the DRO starts at $100 in the picture.
Don
Here is where I found these Shop1103304985 Store. There are alo smaller DX32 in there for about $2500
Yes, when I was sailing in New Zealand and Australia most yards and marina's had converters available to give us 110 60 hz power so I am sure they are available going the other way
I'm a big fan of the display on the TouchDRO. Likewise how it functions when doing things like bolt circles because the display shows you where you are in relation to where you need to be.
Ditron does that too and has done it for at least 3 yrs now.
IMHO, the big advantage that touch has is easily upgraded software and lower cost if you already have or can buy a low cost used android non-samsung tablet. None of my Samsung stuff will work with the touch.
The software is easily updated on Google Playstore.
I believe Yuriy’s has a fix for the Samsung glitch. He talks about it in his forum on Hobby Machinists.
D :cool:
There is another problem. It is a 220 V 50HZ machine.
When I was running a small gold mill in the early 1990's the BC Bearing dealer offered me a bunch of 5hp 50hz motors 3phase. I said the same thing....50hz????
He said it would not matter. I went and talked to a industrial electrician and he also stated that it would not matter, so I bought 10 motors for 10 each. They worked out fine.
Anyone with a VFD knows you can drive a 3 phase motor at 15 cycles 50 cycles or 90 cycles, pick your rpm.
Running this with a VFD to make 3 phase will allow you all the options.
Hi David
Any chance you could take a picture of the cable end on the mag scale? I wonder how compatible they are with older displays. My boring mill has readouts on all three axis but only one mag scale reads. I don't want to order something that won't fit.
Thanks
Martin
This is where I got my scales.
Check out the TouchDRO channel on YT.
D :cool:
I looked in vain for this. Any chance you have a link?
Nothing about it in his website either.
Hi David
Thanks
Martin
If you look at the Aliexpress listing it shows the pinout of the connector.
Post #23 of THIS THREAD.
I should have linked it before but I was on my tablet. Bottom line, any version from build 2023-09-23 forward is supposed to work around the problem.
I don't see anything on the TDRO web site, I think there was but it's probably overtaken by events because of the fix in build 2023-09-23.
D :cool:
Mag scales are stupid cheap right now.
That said, on a lathe Z axis I'd use a glass scale for ease of installation. Drill and tap two holes and the scale is on. If your carriage has provisions for a taper attachment there may even be drilled and tapped holes that could be used for the read head mounting.
When I did my lathe & mill about a year ago (6 scales) I engaged Ditron via their chat on Aliex and the pricing was significantly different from their Aliex page. They threw in 1u resolution N/C and the linear (glass scales) were a fair bit lower in price compared to the magnetic. If you hesitate for a day or 3, you might get a better offer or something thrown in too. That's how I got the 1u for free. If I recall I was close to month end too.
For buying a mag read head it was less costly to buy a short mag scale than just the head.
I'm quite happy with my glass sales so far and the tape mag scales I put on my mill quill and embedded in my lathe cross slide have performed well too. The tape is great for confined spaces but I'm more trusting of the durability/reliability of the glass type.
I'm interested in the latest market info because I'll need to be fitting up my newly acquired SM 1120.
D :cool:
D :cool:
I have mag scales on my mill because I wanted the compact form factor. On the lathe I'll likely do glass scales.
