DRO install phase I...….
After much agonizing over which side of the mill to install my DRO display, I finally concluded as
@David_R8 did the right side is the only real option. Hell, I even agonized over what size cap screws to use LOL. Ended up using 1/4-20 as I have a drill bit of the appropriate size, the correct size drill bit for a M5 screw kind of eluded me.
As you can see, the LH side of the mill gets a little crowded with the belt cover open. I was sorely tempted as the RH side bumps into the down feed handles by a smidge.
Man cast iron drills and taps nicely, that was the easy part
Monday I take the table and saddle over to
@RobinHood to have lubrication ports drilled, Gibb adjustment screw holes installed and DRO scale holes drilled and tapped.
More to come...….
