I have quickly gotten use to the last digit fluttering about.
If they are twitching while you're machining, turn shake on (see Filter Display Value).
What does it mean "while the axis is encoder"?@Dabbler is that WOW that's good or WOW tha
Easy-Peasy. Touch off your edge finder on one side and zero that axis. Move to the oppose face and touch off again then hit 1/2 and what ever axis you are working on, then move that axis until your read zero or 0.000blaaa
Oh. I dont think I would have even figured out what encoding meant. ThanksAhhhhh, I think that should read encoding i.e. moving.
The grease fitting cleaning tool may work too if it has enough capacity to do at least one oil point. then just re-fill and repeat.
Are you trying to tram the vise to the spindle?
I don’t think you can effectively tram a vise using a square.
I tend to use mine a lot for doing things like this — putting flutes or grooves into adjustment handles or lock rings. This one is 6061 aluminum and just plunged with an end mill around the periphery (slightly less than half the diameter of the end mill seems to work nicely both aesthetically as well as for feel)
-frank
