One of the reasons my South Bend is supposed to be able to do cutting off operations from the front rather than an upside down cutter from behind the work is that the cross slide is pushed/pulled from the back with a telescoping shaft. This means the taper attachment just gets positioned and clamped to the bed and then the cross slide is moved by the guide on the now fixed taper attachment.
This makes tapering really easy.
Here's a link to how to use the taper attachment. However they call it a telescopic cross slide screw that must be fitted at the factory. So the thing to check is to see if your lathe has that sort of mechanism. Otherwise, like the 9" version, the cross slide nut needs to be disconnected.
