Radial engine build
Give the threads a very slight sandover with 600 grit wet/dry paper bonded to a flat stick. I make my own by the dozen using 3M spray adhesive. This cleans up the tops of the crests which can have raised burrs from threading. Then with the chuck still spinning I use this rotary polishing spider which does a great job of cleaning the threads. I've gotten into this habit because it doesn't take much time & helps condition the threads. I found when I was single point threading fine threads, half the issue was +/- false measurements.
Leftover threaded jig so the head length can be be made batch mode.
Into a jig made from scrap aluminum. The part is threaded into a hole, then a nut to keep it put, then slit 0.025" x 0.050" deep. Then the 2mm ball end mill for pushrod end. Shows how it sits on rocker arm & jeweler screwdriver to make adjustment. Basically done aside from hardening them.
Some overdue items arrived in the mailbox. Aliexpress radius mills, so was able to finish the roundover profile on the rocker arms. 8-32 Mitee Bite claps so made for a convenient way to lock the arm position against a stop pin, flip the part & radius the other side.
I decided to lock the rocker axle from spinning so milled a flat & tapped a teeny M2 hole in the perch. the axles are hardened now.
The rocker perch get these rings Loctite in counterbore so they self align to the valve hole.
Fiddly bits, fiddly bits, endless fiddly bits....
Thanks Johnwa, yes I've seen that vid. What impressed me is he is building a FS engine on hobby size lathe & mill. Never underestimate the power of a hobbyist amateur on a mission! LOL
Seems like VW engine parts are somewhat suited for aeronautical powerplants, at least among the homebuilt crowd. I've see other cylinder layout configurations.
Well I've been deliberating over the lubrication issue long enough, it was time to bite the bullet. The original design calls for the nose case to be partially filled with oil so that the cams & planetary gears get splashed. That part seemed pretty straightforward initially. But as time progressed some nagging thoughts I had started to become more clear. The nose case chamber is isolated from the crankcase with O-rings on the front gear plate which were kind of a PITA to make but they seal. Issue-1 is I think oil is going to get by the submerged tappets on the bottom side as they are working away. Issue-2 there is a crankshaft bearing in the nose case which is specified as sealed but I think oil is going to make its way backwards into the crankcase through the seals eventually. In methanol glow engines we always remove the internal shields because the methanol acts as a solvent on the grease over time. The premix oil is completely satisfactory to lubricate parts. The brief German instructions make reference to 'sealant & silicon' which makes me suspicious.
After some research I concluded this engine (well and his 9-cylinder) is the only one I've seen with an oil bath chamber like this. There are engines with scavenging oil pumps (to late for me). And there are engines including several commercial radials with apertures or windows that allow the raw intake charge mist to flow around & coat all internal parts. I was a bit concerned of the distance though, mist reaching forward ina tortuous path to coat the cam plates. But every RC engine I have ever dismantled is liberally coated with oil everywhere, all the nooks & crannies. Sometimes too much, often you find puddles in low areas. Many engines have a blow-by nipple to drain buildup fuel/oil residue.
So... I decided to modify my existing parts
- nose case will have a screw in fitting to squirt a bit of heavier weight oil over the cams before a run just for insurance
- front plate will have openings to allow forward mist flow
- ring gear cup will have holes to match the cam plate holes (which I did before hardening in case this day would come)
Putting these new features on the parts required stepping back & making jig plates so alignment could be established again. It would have been easier when the parts were made, but oh well.
Drill jig for ring gear cup which the cam plates are bolted too.
Jig for modifying the front plate. Its a bit swiss cheesed with the new holes but its 2024 alloy & well supported so hopefully strong enough. I managed to get the 2 lower holes slightly intersecting the gear cluster so hoping it gets directly misted. Fingers crossed. I'll just have to be careful during break-in runs to open the nose case early & often to see how wet things are.
I found an RC post where a guy acquired a commercial radial made by O.S. & began refurbishing. Unfortunately it was in sad shape. The original owner just let it sit for a couple years, never inspected or applied after run / storage oil coating to parts. Between the methanol fuel & acids in the oil, corrosion can set in quick & get real ugly. But the pictures told me wherever there was rust there was fuel mist & it was alll over the cams, gears & bearings. AFAIK nobody has ever seized an engine in these areas. Seems primitive but I guess it works.
The next thing on my 'less than happy' list is induction manifold assembly. The original design had the tubes going into counterbores with recessed O-rings to seal the tube. I wasn't keen on machining those but mostly the end result seemed sketchy on multiple fronts. How to get the candy cane intake tube in the hole landed in O-ring then shimmy the other end into the head with a threaded coupler over the trumpet end.... Ack! I could see those O-rings leaking & leaning out the mixture or worse. So I made extended manifold pipe-etts & figured I could mask the connections with a hose coupler. I was not thrilled by the geometry & miters but just put aesthetics aside for now.
Then (3 years after the fact) I started to think about the RC carb I bought & for which the manifold was machined to match. The plans mentioned an engine no longer produced. I thought it was a 0.40 CI engine, but turns out it was actually smaller. The issue is after a lot of searching & digging I'm pretty certain the 8mm venturi throat is too big for this engine, it should be more like 5.5-6.0mm. I'm not after max power necessarily but too big a throat & it doesn't draw fuel properly for idle & transition. Turns out RC engines are becoming more & more scarce these days as the hobby shrinks & people are going electric. I found some carbs online closer to correct size to test but the body diameters are different. So that was the final nail in the coffin. I decided to redesign the manifold & clean up all these issues simultaneously.
The CAD exercise highlighted why my tubes were never going to match no-how. It would have to be a funky 3D shape to come off the head on one axis & end up in the manifold at another axis. The plans led me down the garden path. Its hard enough to bend tubing in 1 plane to a target angle, never mind this 3D challenge. I know some guys fill them with bizmuth or whatever but they still need to be shaped consistently.
So my plan is start with 'simple' tubes made from my fixed radius bender with straight segments on either side. Quite similar to what I have actually, but now the manifold ports will be properly realigned to suite. I also made provisions for a standardized carb adapter plate so I can just bolt on any carb with whatever body diameter & leave the manifold alone. I also altered the engine mount lugs which was another thing that bugged me. Slowly...moving....forward.....
I always feel like a caveman after reading your posts. Thank you.
Fantastic stuff! Motivates me to keep learning. Keep it coming
I am clearly late to the party but when I searched the forum I stumbled on the castings thread and steam engine stuff, This is a whole new world. Very impressive stuff peter, I must admit my reasoning behind my machinery is for this stuff ( steam engines / hit and miss / hot bulb etc etc ) as well. I will keenly keep an eye on this thread and read through it all and digest it ASAP.
Thanks for sharing and keeping this thread alive.
I don't think I showed making the intake pipes so here are some pics. As mentioned, I wasn't happy with the stock design manifold & how the pipes made those miters, but part of that was I was limited to my hand bender which had a defined radius. So bottom line was either make a custom bending tool in order to bend a specific radius (lots of work) or accept the bend radius of my tool & redesign the manifold & piping system around it (slightly less work).
Most of this stuff is specific to fitting the engine, so after some fudging experimentation it was basically repeat the ritual. The tubing is 5/16" OD aluminum Versatube from AS&S. Unfortunately they send the material coiled in a 6" box which is a PITA to straighten. I was too lazy & impatient to make the roller straightener tool but I will eventually. The pipe section is only about 4.5" long so I lightly pre-rolled it between to pieces of hard MDF pizza dough style until I had a straight segment to begin with.
Shows my trumpet flaring die. The plywood on the end is so I could cut the excess & face it exactly square. Then it has correct stickout for the flare. Slight chamfer helps
My home brew flaring tool. That face gets dressed slightly too.
