Just need to drill and tap some pieces of 5/16” Dia. CRS for connection anchors.
All good !!
There are billions of ways to use 123 blocks. What's the 5/16 connection anchors all about for your intended use Len?
All good !!
Finished early today so I worked on the anchor hardware and a setup for the 123 Blocks.
Just noticed the ends of the threaded anchors.
I think I should trim the length a little.
You are correct @PeterT.
There are (5) 3/8” UNC holes thru the I” thickness of the blocks.
All the non-tapped holes are 0.350”.
I grabbed some 5\16” CRS Rod material and cut a few 2” Long pieces. After milling a little flat, 1/4” UNC tapped holes were machined into the 5/16” rod to anchor the screws and act as drawbars to pull the blocks together.
The 5/16” Rod will center in the 0.350” holes while the surfaces of the Blocks contact each other and create square corners and location datums for additional tooling.
These blocks can be assembled in dozens of arrangements to create tooling supports.
Very useful for assemblies and machining setups.
@SusquatchAnyways, here is my fasteners & T-rod with the blocks removed from prior posted picture. Hopefully makes sense now.
I’d try a carbide end mill, not a carbide drill. Maybe a 4 or 5 fluter. EM should be more rigid than a drill. If that does not work, grind the holes.
I don’t think you are missing anything. The 23 hole 123 blocks are not designed to bolt together like you show. They can be held like that with T-bolts - ie additional hardware. You need proper Moore & Wright 11 hole 123 blocks for that. The green circle shows a set on Don’s desk. To the left of that is a “proper” set of 123 blocks bolted together to form a 90* angle as per design.
Don't feel bad it happens, I'm 20+ years younger than you and that seems to happen to me all the time now. I'll be tickeld pink if I can get to your age and still think as sharply as you. Not likely with my geneticsI think my age is interfering with good clear thought
123 Lego blocks?I see. I wondered why the blocks with fewer holes.
If this is so, then I guess I should try to patent a new 123 block with better interconnecting.
Just kidding.
