New to me Ammco 7" Metal shaper
Truer words have never been spoken....... That being said, when time is on your side it's time well spent. And with a sharp shear tool and a light cut you would almost think it had been ground....
Exactly! You can do with REALLY cheap tooling, what would cost you a great deal more, if you wanted to use a Mill or other tools.
If you want to go fast, use another tool. If you are okay with slow speed, you can get it done, eventually, for pennies!
If you start to understand the so-called 'optimum' speeds and feeds, take a note that they are designed for a commercial shop to strike the balance between money spent, and money earned, not about making the best possible finishes, or the least risky set-ups.
Shapers in a Hobby environment, have no need to be run balls-to-the-wall, and in truth, trying to push the speeds and feed up to what is considered commercially viable, has long since proven to be a money-loser for most commercial shops. Which is to say, there is a reason they claim that you can make anything with a Shaper, except a living!
Slower cuts put less wear on the machinery and tooling (as cheap as it is, it's kinda nice to preserve it for use again later).
And, you don't have to ensure it is all bolted down to the Continental Shield in order to be sure it will still be sitting in the same corner of the shop when done...
If ya gots a Missus, ask her if slow, comfortable and smooth is alright, vs. trying to ride a jackhammer every time! :)
Seriously, slow is OK. I pretty much guarantee that you will spend more time obsessing over the set-up and planning, of the cut, than you will actually cutting. As much as I am a fan of time efficiency, this is not a place to rush things. Nor is it the tool that you would pick, if time, truly, was of the essence.
I don't disagree with any of this. I think what I was trying to say was that many people are under the impression that a shaper is necessarily slow and incapable of running ...um..briskly, which ain't quite the case. Whether it's always appropriate or a good idea is another question.
One of the problems with running faster is upon the return stroke the tool hits the edge of the work and bounces leaving a mark about a inch or so from the edge.
I thought you set the cutter so that would happen to the work piece where the next stroke would go so as to not mar the surface finish.
I have the DoAll bandsaw but not a horizontal saw. As such I am not familiar with how fast or slow they are. I bought a power hacksaw a month back and I don't really know if it's fast or slow either. I load it and go and do something else, it beats me every time. Lovin it.
I used to freak out the other guys in my shop, because I would weld up a, essentially, wood bandsaw blade, and then proceed to go to town on thick aluminum plate with it. Usually 3000-5000 Feet per second speeds, like, right at the top speeds the saw could handle! I would use the same 3-4 TPI blades for cutting thin sheet (use a layer of plywood under, to support the material. Learn to not gronk the material into the teeth, and you get a pretty good surface finish!
My record, for a "stupid-strike" was while I was returning the coil of blade material to it's storage (less than three steps away!), one of the idiots in my shop decided he needed to cut a piece of crappy angle iron, so he did that with the brand new blade I had just made... Double stupid, since we actually HAD an Ironworker, in the shop! <spit>
My son has done the same
Looks like that 1/2 horse motor isn't gunna work after all. It's fried internally. Thank God, I plugged it in before I drilled any holes in the shaper bracket. Magic smoke filled the air. Turns out the bearings are toast too.
I found another free motor today. This one is a blower motor. It uses a start winding and a centrifugal switch and has no capacitors. I'm hoping it has enough oomph to get going against the shaper inertia. We will see.
A few questions. The motor direction is not spelled out in the manual. I assume the motor direction has to be such that the quick motion is the return stroke. But maybe one of you guys has an AMMCO 7 and knows which way it should turn.
And about what size should the motor pulley on this thing be?
I put the pulley sizes and motor speed I have in post #90. I think my motor is turning backwards, can not get it to turn the other way even with the plate wiring pictures. The stroke looks faster on the forwards stroke, but, difficult to see.
Yeah, the forward (power) stroke is at the 'top' of the arm inside the shaper, and the return is much faster as that occurs on the 'bottom' side of the arm. Best mechanical advantage for each use!
You can either do the math, based on the strokes per minute in the manual. or you can likely just grab a pulley that 'looks about right', and it probably will be (unless you have delusions of grandeur!).
Like I said before in this thread, shapers is a slow motion process, without much to be gained from pushing things harder than they need to be... Set-up/planning is gonna eat the time, and you cannot ever make a shaper work fast enough to gain that back. Shrug your shoulders, and accept that as reality! :)
Thank you for that. I skimmed this thread and @TonyK's thread and didn't see it, hence the question. Did your motor pulley come with the shaper?
I think @trevj has the right of it. The internal arm that drives the Ram from the bull gear eccentric should push the Ram forward when the eccentric is at the top half of the bull gear. The arm is pinned at the bottom of the housing and engages the Ram at the top. So the highest leverage and lowest Ram speed will be when the eccentric is on the top. That's what I had guessed from examining the leverages. I'm glad he confirms that. I like it when things make sense.
My motor turns the wrong way right now too. But being a furnace fan motor, it is reversable. I had contemplated putting a drum switch on it so I could reverse it easily, but I have not read anything anywhere that suggests there is any reason to do that.
Sounds like you either need to reverse your motor or go looking for a new one. Driving the Ram on the bottom half with over stress the gear eccentric and arm - not to mention driving the cutter too fast.
I didn't see any strokes per minute in my manual or the others posted here. For the time being, I mounted a 2 inch - which just happens to be what @Bandit is using.
I always have delusions of grandeur! So, don't be raining on my parade you!
But seriously, what are you cautioning me about? I know so little about shaping that my delusions are mostly about baby steps like making my first chips!
I come from a different world than you Trev. My target reality is exactly what I'm gunna get. Beauty in my eyes is slow and steady. At my age, I'm not in a hurry to do anything any more. Setup and planning is the best part! I can always make one or two test chips next month.
Is this what you meant Trev?
Hardly a chart, but not hard to try to get close.
Yes the motor pulley came on the the Shaper when I got it, HOWEVER, I do not know if it is original, I know I am at least the second owner, the person I got it from was 20yrs.? younger then me, so very likely, I am at least the 3rd. owner. It has a Rockwell Delta branded motor on it, everything looks original from the pictures I have seen, but not going to swear to it. I tried the high speed, THATs not happening!
You mean it's been running backwards for decades????
Ya, top speed in reverse would be SCARY!
Don’t know if it is running backwards, I say it looks to be moving faster moving ahead, then back. Could be a seeing thing, am needing to look see if on forward stroke the eccentric is on the upper half of the bull gear.
I think @Dabbler did bit on how and why the speed were different as a pulley/gear/wheel turned. That got me looking and wondering. Which then turned to to a large amount of muttering and a selection of “anglow Saxon” words as reverseing the motor was attempted.
Should be pushing forward slower than it retracts. As described earlier, the ram should be moving forward, when the (oh hells, trying to recall the terminology exactly. Dang!) eccentric driving block is in the 'top' portion of the driving arm, so it gets the best mechanical advantage driving the cutter, and when it has almost no load, in the lower part of the internal split arm of the shaper, it retracts faster than the cutting stroke was.
On the bright side, you have a small shaper, and guys with small shapers, including the prior owner, most like, tend as a group, to not try to load the thing up so as to make the electrical Meter squeal! A shop with a 36 inch stroke machine, trying to make a buck with it, will push that machine a LOT harder, and likely suffer a blow-up, if the direction of rotation was reversed. The leverage is all wrong for reliability.
