Stick them on the flat part
Easy for you to say....... But that's like asking me to tie my shoes. I can't bend over far enough to see anything like that. The handle lip hides them unless my head is near the floor.
I use a paint pen and hand-write the drawer contents. A bit of solvent and I can change what's in the drawer.Easy for you to say....... But that's like asking me to tie my shoes. I can't bend over far enough to see anything like that. The handle lip hides them unless my head is near the floor.
Something like these. I know there options out there but finding the correct one to fit is the issue!
Clip-On Label Holder 2 3/4" wide x 1" high for Rousseau Dividers, 60/Pack (RG51-275) - Innovo Storage Systems
Details Pack of 60 Clip-on Label Holders Holds a 2 3/4″ wide x 7/8″ high cardboard/paper label Designed for use with Rousseau RG10 Dividers Features Made of transparent, matte plastic that eliminates glare making labels easy to read Can be attached to Rousseau Brand Metal Dividers Only Once...innovostorage.com
If only you could 3d print a little wedge shape standoff that would mount under the drawer pull to the drawer face with a spot for a label mounted at say 45* or something easily readable from the top.......
Grab some utility grade aluminum sheet and make up some small brackets to mount the label on (as usual, using our tools to make more tools & accessories…..).
Mill a flat spot on the handles?
**Have a look at the fine print on your shrink label. The Casio tape is said to be print on shrink sleeve but they say it does NOT have the insulation properties (voltage breakdown resistance etc.) of real electrical grade shrink sleeve. Said differently, it’s probably about as good as Scotch tape! Fine for labeling so perfect for most of what I want it for.
Another solution to the tool chest handle issue is.........new tool boxes
It appears the PT can do 1" labels compared to 3/4" for the Rhyno - can they both do 2 lines of print?
I believe that I read somewhere that the BT has a higher resolution (pixels or whatever) than the Rhyno (2400 vs1200 are the numbers coming from the back corner of my memory bank, yea that's dangerous, but I couldn't find specs confirming this)the PT prints MUCH BETTER small fonts. The Rhino almost becomes unreadable with XXS and XS.
