true. it works best it there is a small thickness put on first, and given 5 minutes to start to catalyze, then another layer, etc. if it isn't skimming over when the next coat is applied the layers bond.Moisture from the air will diffuse through cured silicon to reach uncured silicon which will then cure too.
We're talking 3/16" tubing here with a roughly 3mm diameter wire assembly going through. So it would be a thin layer of sealant. I found some exhaust sealant at Cdn Tire. Good to over 500 degrees. $10 or so experiment.true. it works best it there is a small thickness put on first, and given 5 minutes to start to catalyze, then another layer, etc. if it isn't skimming over when the next coat is applied the layers bond.
Not sure why the thermister temperatures don't match.
The PC display errors are due to me not reading the user guide. The values now match the display.Easily both the thermistor and the two 1% resistors making up the voltage divider.
Try not to let the wife know that you read the manual, it'll be expected of you all the time.....🙄The PC display errors are due to me not reading the user guide. The values now match the display.
Actually badly written software. I've selected that the first two bytes in Little Endian Format are a signed number that goes from -32768 to +32767. Because I've selected Int16 the Unit fields at the far right should be changed to read:The project is meant to test your knowledge, the manual is for troubleshooting.
