This is the outside wall which has the carport on the other side. What's interesting is the footing on which the wall is built is actually level. The floor slopes downward towards the centre of the lower level. The entry into the carport is actually a step up onto the pad. The carport is now the shop with all my metal tools. The other side of this wall is still stucco. One day I really should remove that.
In this photo the distance to the top of the footing from the shelf is about 2". At the other end it's about 1/2" above the shelf.
Back in the last Century, I worked for a Hardwood Floors Co. that had a "Commercial" License, and we did a LOT of Wineries.
I went to one, where my job was to shoot down "stickers" to bring the floor to a particular hight, as they were going to HEAT the room via Air Circulation under said finished Floor.
I had the Standard Floor Layers "Inspection TOOL" a very ridgid 10 foot long "I Beam". This provide a *TRUE* flatness of 1/8 inch (maximum deflection) Along that 120 inch beam.
I started on the theory, that the Concrete subfloor had a REASONABLE LEVEL-NESS to it, I mean the Winery machinery floor, was in the next room • • • • •
Well, within Moving the TEST BAR, TWICE, there was a HORRID discrepancy: over an INCH+ in 10 feet!
WHAT? I had done this process a DOZENTY* times before . . . definately OUT OF SPEC!
After Arbitarily examinining a few more check points, I went straight to the Main CONTRACTOR, and showed him my results • • • • • • • •
HIS REPLY, was Priceless, it seems they set up the transit, in that DOORWAY, to bring concrete level from the crushing room area to the room I was to work in, AND SOMEONE knocked a leg out of place ! ! !
ONE "would assume" that they did a Re-Check on ~The HORIZON, et. al.~ But you folks Up NORTH know that making Assumptions • • • • • • • Creates a DONKEY in the room :-}
I called my Boss spoke of the INACCURACY, and the needed extra time to *LEVEL THE WORLD*, and he said "NOTED" ! ! !
The Total Variance in "their level" AND the WORLD that I worked, in was over Two INCHES, Not at all worthy of a Company with a Commercial Contractor's License. More in line with the Three Stooges, or even the RED GREEN Show (Canada's BEST HUMOR exported to Down South),
• • • I can change, if I try • • •
Just to ANNOY those other Main & S0ub Contractors, EVERY TIME that I fired my 22 powered Nail Gun, to attatch the stickers, I YELLED, "FIRE IN THE HOLE", a quasi legal requirement in the State of Califusion, just South of Oregon (B.A.G.)
*Oh, "DOZENTY" is a Down South of the 48th parrellel saying that means many Dozens but Less than a Few Hundred'eeees . . .
OK, I need my wake up COFFEE, I should never Right, err Wright, uhh, WRITE before coffee,
Exit, STAGE Right, hobbleing on three legs, so to speak (cane in hand), COFFEE Maker SMELLS approaching my Nose, (Its a Long Fellow)
philip, from the Great Pacific NorthWET, Oregon, USA
"Wood Working" & "Electronics", since 1957, Metal working added, 1968
