Shop Is your shop messy or spotless?
Shop
What does your shop look like?
  • A total junk yard
    Votes: 12 12.2%
  • Organized Chaos
    Votes: 45 45.9%
  • Well used but messy
    Votes: 31 31.6%
  • Jam packed but room to move
    Votes: 30 30.6%
  • Not enough tools to be really messy yet
    Votes: 6 6.1%
  • Everything has a place & is in it
    Votes: 19 19.4%
  • No clutter anywhere - nothing on surfaces
    Votes: 5 5.1%
  • Spotless - you can eat off the floor
    Votes: 3 3.1%
  • Showroom Shop
    Votes: 0 0.0%
  • Total voters
    98
One of my favorite recent additions to my shop is "project bins". Each project gets a plastic tote containing all the pieces in process, from raw stock through to finished. This has done wonders for keeping my benches clear(er) and my project parts together, and the little bins stack and accept sharpie really well. Amazing what spending $30 at Industrial Plastics did for me.
princess auto is your friend in this regard. They have the perfect sized totes for most projects. Strong enough, just the right size to be easy enough to lift without getting hernia and yet large enough to hold everything.
That's what I do. There is one problem though. After a while you have 42 different plastic project boxes. 😱
And now the AR3 Robot Arm is already too small and I need to upsize it. Can't even see the bearings under the connectors and switches. The 3D printed parts don't even fit in this one.
I'm proud of the layout I have put in place to fit everything I have in a way that still gives some room to move. However, I always have projects on the go, and I realy don't understand the benefit of putting everything you're still using away when you stop working, unless you have come to completion of every active project.
In that case, the only time my work bench doesn't have common tools sitting on it is right after I decide to clean the shop.
I saw the top of my welding table the other day. Even wiped it down with brake cleaner and a rag. It'd been months since the last time that happened.......
It's full again already with something new....
I wipe mine down with WD40...would rather it not rust, so removing all the oily/dirty goodness with brake clean isn't ideal.
Though I don't mind working in a messy environment I've come to think that I should pay more attention to the hazards that build up over time. I've started working a bit with fiberglass as a cheaper handle material for my knives, and the dust that comes from shaping that with a belt grinder is extremely fine, which I don't often realize without a respirator on.
Next to frequent lack of ventilation, the saw dust from combustible materials begin to smolder quickly from welding slag or sometimes just larger sparks.
sorry to play to play the net nanny, I generally dislike them meself and I know you know what you are doing 🙂 ..... but for posterity, break cleaner and welding don't go together. The residue with heat produces phosgene gas - deadly even in small doses. Yeah, I know, use non chlorinated, great until someone grabs the wrong can or someone isn't aware and grabs the brake cleaner to clean....
Great advice!
I've almost completely stopped using WD40 for anything but cutting aluminium. It is so totally useless for rust prevention & lubrication compared to alternatives. It dries off too fast.
I frequently use spray oil. The problem is that spray oil is actually hard to find. No idea why - I would have thought it would be everywhere! Remington gun oil is available online but big $ for the purpose. So I fill a spray bottle with a thin multipurpose oil and use that.
I also like to keep an oil rag handy.
WD40 is better than brake clean and relatively speaking it's fairly cheap. I definitely never use it for lubrication either, but rust prevention it's better than nothing and definitely better than something that strips everything off. For a welding table I prefer it not to be too oily either. If I'm really going for rust prevention (longer term storage) I typically go with fluid film. On the machine tools, they've got enough cutting fluids and way oil and whatnot to never be an issue 🙂
