Mine works as both.
My garage furnace has a two wire igniter that is separate from the flame sensor. High voltage sparks dance between the wires lighting the gas. The house furnace has the white hot ignitor. Different ways to the same place.No, it gets white hot and then the gas turns on and lights.
this is it.
Furnace trouble again. I went in to the shop this morning and it was +14.5C instead of 20C as it should be with the thermostat timer. Same as last time - almost a year to the day and I'm taking the damn furnace apart again, cursing the designers, busting knuckles. I have to use about 3 wrenches and a flex shaft to back out the screws holding the sensors in as the access is so poor. Right angle behind pipes with mounting brackets in the way too. I cleaned the ignitor and the sensor as both were dirty - same problem as last year. Seems to be working again.
Oh man, furnaces seem to have a way of giving trouble at the most inopportune times. I have a brother that has had various furnace problems (not all same furnace) over the years and it always seems to be around Christmas time and/or the coldest snaps of the year.Furnace trouble again. I went in to the shop this morning and it was +14.5C instead of 20C as it should be with the thermostat timer. Same as last time - almost a year to the day and I'm taking the damn furnace apart again, cursing the designers, busting knuckles. I have to use about 3 wrenches and a flex shaft to back out the screws holding the sensors in as the access is so poor. Right angle behind pipes with mounting brackets in the way too. I cleaned the ignitor and the sensor as both were dirty - same problem as last year. Seems to be working again.
No kidding Don. My house furnace motor packed it in on Christmas Day a few years ago. I think these furnaces are testing me.Oh man, furnaces seem to have a way of giving trouble at the most inopportune times. I have a brother that has had various furnace problems (not all same furnace) over the years and it always seems to be around Christmas time and/or the coldest snaps of the year.
I think my time for trouble is about due. I salvaged a furnace from an older house that was to be demolished and installed the furnace in my house. The furnace was only about 6-7 years old at the time but that was 20 years ago. I had one flame sensor go bad o it once but that is it. I'm now 500 miles away at the inlaws and hoping my furnace doesn't pick this as the time to fail.No kidding Don. My house furnace motor packed it in on Christmas Day a few years ago. I think these furnaces are testing me.
50,000btu ng heater
Sorry to hear about your furnace problems again John. You seem to be carrying an unreasonable portion of the bad luck with respect to furnace karma on this forum.Furnace trouble again. I went in to the shop this morning and it was +14.5C instead of 20C as it should be with the thermostat timer. Same as last time - almost a year to the day and I'm taking the damn furnace apart again, cursing the designers, busting knuckles. I have to use about 3 wrenches and a flex shaft to back out the screws holding the sensors in as the access is so poor. Right angle behind pipes with mounting brackets in the way too. I cleaned the ignitor and the sensor as both were dirty - same problem as last year. Seems to be working again.
Heee heee heeee. Spoken like a consultant John. How many times have you used that line when handing a client an invoice? I love it.The money wasn't for hitting the thermocouple, it was for knowing where to hit
