I hung a home furnace from the ceiling. Most of them can be safely installed on their side and it's usually pretty easy to pick up a lightly used one on Craigslist or the like.
I paid $250 for a 2yr old high efficiency gas furnace a couple years ago. Less expensive to run and quieter than standard "garage" heaters.
All good points Tom. No doubt a garage specific heater can be the better option for most. A home furnace isn't the solution for everyone.I also thought of going with "regular" used home heater but went against it and got garage heater instead.
Main issues with home heater in garage:
1. its big.
2. needs ducting
3. not optimized for garage heating (usually way too big)
4. used, no warranty, you don't know exactly what you are getting
5. expensive repairs are far more likely vs. garage style heater.
Actual $ savings are not that much as biggest cost is installation, unless you are licensed to do it yourself. This is also why I went with premium heater - not worth going cheap, it would decrease the price by like 10% at most.
That looks like the same unit I got.I bit down on my cheapness and had a reznor installed. I hope this is my last post on this topic.
For the first 15 years at this place I used an old furnace I bought for 75$ for my garage heat. wasn't particularly efficient, but it did the job well, at not to great a cost, and heated the garage *quickly* (that's what 120,000 BTU will do). I left the garage very cool (at about 0, and only heated it when I was working.
Sadly it died, so I went with a Princess auto 50K BTU instead. It just keeps up. More insulation went in this winter, so I cannot wait to see how it fares next winter.
Insulation is key. My shop furnace is only 75k BTU and even at -40 it keeps up no problem. Shop is 1800 sq ft with 14' ceiling height. The little wood boiler heating the slab is just supplemental to keep the propane bill down. Slab is insulated below and around the perimeter, R22 walls, R50ish ceiling, will be increasing to R70.For the first 15 years at this place I used an old furnace I bought for 75$ for my garage heat. wasn't particularly efficient, but it did the job well, at not to great a cost, and heated the garage *quickly* (that's what 120,000 BTU will do). I left the garage very cool (at about 0, and only heated it when I was working.
