Electronic lead screw ELS - Rocketronics solution on Modern Tool C0636 lathe
@gerritv good solution to the cross slide hitting the motor & mount. I think on my lathe I could cut down the cross slide as the part that sticks out past the end of the dove tail isn't doing anything anyway. That seems drastic though - I'll see how my big standoff works and either keep it OR adopt mounting on the side with a pulley as you did Gerrit.
So today I figured out how to get my high flow 0.8mm nozzle working on the prusa. (Bond tech chat nozzle) Using it I managed to take a 6 hour print job down to 2.5 hours! I used the prusa supplied print defaults in their slicer for 0.8mm nozzle and also turned up the print speed to 120% without any consequences.
The results are cruder no doubt but it feels heftier and is stiffer / stronger too. The dice objects are the voron printer test print objects. One is 0.4mm nozzle at 0.2mm layer height - the other is 0.8mm nozzle at 0.55mm layer height. It’s cruder no doubt but if you don’t need the resolution then the high speed is a great trade off.
Interesting the supports were cleaner and easier to rip off with the 0.8mm nozzle. I think I’ve got a better doubling speed now. Hopefully that will keep me going till the prusa XL ships. I think it might be here by Christmas.
Anybody interested in speeding up their printer I suggest one of these high flow nozzles in a larger size is a pretty good option.
Look at all these revs…
That's what makes 3D printing so cool. You can revise to your hearts content till you are happy.
Now if only I could get Fusion to like me. Holy crap it's painful. I barely figure out one thing and it bites me again!
Anyways, very cool mount John!
There is an imperial option for the non-pro ELS. After a few years of using my Pro I just pre-doodle the numbers if I am forced to do stuff in inferial. It is only 2 numbers, one for Z, one for X.
I had wanted features of the pro version.
I've since seen the open source NanoELsH5 and given the nextion display and cost I'm going to have my techie friend make us a few to play around with. That way we can write code for any operations we wish that are not already available... and have embedded measurement conversions
I hope it works out for you.
I don't have fond memories of the original Russian Electronic Guitar code this is based on. Looks like he has done a lot of clean up eventhough it is now a single file of approx 4000 lines of code. (not a fan of that)
I haven't looked at the code at all yet... I've only watched videos of how the controller operates and how to use it with gcode as well.
The thing is, being based on a nano, and having a large touch screen, and a cost of under $125 CAD it is worth kicking the tires....
Between my friend and I we could rewrite the code entirely if needed....
