@Canadium I haven't see this. Perhaps on cheaper wood-style aluminum oxide sanding paper, but I use cloth-backed or mylar sheet abrasives. I think some grit goes astray, but always use a fluid lubricant liberally to wash any away. I used to use Varsol, then low-odorur Varsol, but now I'm using 90%+ isopropyl.
Another trick is to use die stones for the roughing work. The stones ablate - they form to the curve, and remove stock as evenly as the pressure of the operator. In this case I'd use ultra fine on the curves surfaces, and take it very easy. the flat surfaces get very fine files and high grit wet and dry paper - all well lubricated with isopropyl.
I'll look up my supplier. I think it was HH Roberts, but I'll post below.
