made a duckboard for the lathe
Never heard that term. I like the chip slots. I have an antifatigue mat with no holes that a machine shop was pitching. I'll be interested to hear how your duckboard works over the long term.
They work very well at reducing leg and hip fatigue from standing on concrete.A lot of older machine shops have them, as scarf falls between them and is not picked up by the shoes. Additionally it acted as an anti-fatigue mat because it added bounce and give.
I have a bunch of those too around my table saw, wood lathe and workbench.I use the cheapo foam mats used in kiddy playhouses. Cheap, easy to cut to size.
The one thing I don’t like about them is that they don’t stay in place.Wife has those around her knitting machines. She uses silicone lube spray on her machine beds.....Those mats are slicker than snot. First time I discovered that was from the floor......
I notch them to fit around the legs of the bench.The one thing I don’t like about them is that they don’t stay in place.
I had them in my shop. Between the lathe and the mill. They filled the space so they couldn't move around. I did mostly aluminum. After 10 or more years the aluminum chips were imbedded in most of them from me walking on them.The one thing I don’t like about them is that they don’t stay in place.
I bought one of these Fiberpunk units to add remote job upload and control to my printer. First one failed immediately. They replaced it quick and without quibble. Second one worked for a several months (since March). The screen started screwing up and now I can't upload anything to it. Junk. Kludgy web interface. I'd give it minus stars if possible. Waste of time and money.I don’t think so? By above my pay grade I meant above my knowledge/ability level
The Fiberpunk unit was so easy to install. The only thing I had to do was plug in two usb cords, insert the MicroSD card adapter and modify the config file on the included MicroSD card so that the device would connect to my home network.
My screen is also going wonky but seems to be still working fine. I'm sorry you had a bad go of it.I bought one of these Fiberpunk units to add remote job upload and control to my printer. First one failed immediately. They replaced it quick and without quibble. Second one worked for a several months (since March). The screen started screwing up and now I can't upload anything to it. Junk. Kludgy interface. I'd give it minus stars if possible. Waste of time and money.
Is there an alternative? I don't want to go down the raspberry pi build rabbit hole - I'm completely uninterested. I want to print not start project 43. I just want reliable and fast printer upload and control. Some googling, etsy, amazon, has not revealed any one building a raspberry pi octoprint plug and play solution. Anybody got an option?
Seems to run just fine in reverse. There’s maybe a slightly different sound to it but seems just as smooth as in forward.Let us know how the lathe runs in reverse -- with the threaded chuck, not often used, but... I hear that link belts are pretty much unidirectional, but for polishing it is sometimes helpful...
