Current Off Shore Order ETDs
Wow, that's crazy. I've heard of similar situations where people have tried to interject normal UPS/Fedex type delivery so they can self clear through some procedure & save the dinger fees. One ofmy RC friends wrote a step-by-step process. It sounded complicated, maybe the shippers play it that way intentionally, I dunno. Glad it worked out for you in the end.
What T&CG if you don't mind me asking?
It's still in China as far as I know....
What is T&CG?
Sorry for the acronyms. Tool & Cutter Grinder. Sorry Kevin called his a universal cutter grinder & that's the machine I was asking about.
Well this is getting just a tad tedious...…….
Been sitting in this state for 8 days now. Check out the open dispute date 2021-01-14😵
You should contact the seller and ask what’s going on.
单号:LZ395416494CN
包裹状态:运输途中
国家:中国 -> 加拿大
目的地:
2020-10-31 16:45, CNCAND,China, International item has left originating country and is en route to Canada
2020-10-30 11:22, CNCAND,China, International item has left originating country and is en route to Canada
2020-10-19 22:02, CNCAND,China, International item has left originating country and is en route to Canada
2020-10-19 21:21, CNCANA,China, International item processed in originating country
2020-10-19 18:48, China, International item mailed in originating country
发件地:
2020-11-01 05:07, 广州市, 已交承运商运输
2020-11-01 03:02, 广州市, 离开【广州国际中心】,下一站【广州国际交换站】
2020-10-31 16:45, 广州市, 【广州国际中心】已出口直封
2020-10-31 16:45, 广州市, 【广州国际中心】退回,备注:安检退回
2020-10-31 16:40, 广州市, 【广州国际交换站】退回
2020-10-31 11:39, 广州市, 已交承运商运输
2020-10-30 11:22, 广州市, 【广州国际中心】已出口直封
2020-10-30 11:22, 广州市, 【广州国际中心】退回,备注:安检退回
2020-10-29 20:49, 广州市, 【广州国际交换站】退回
2020-10-20 04:32, 广州市, 已交承运商运输
2020-10-20 03:42, 广州市, 到达【广州国际交换站】
2020-10-19 22:02, 广州市, 【广州国际中心】已出口直封
2020-10-19 19:40, 广州市, 离开【省国际花地湾营业部】,下一站【广州国际】
2020-10-19 18:48, 广州市, 【省国际花地湾营业部】已收寄,揽投员:黄明忠1,电话:17391391390
Powered by www.17track.net
Number: LZ395416494CN
Package status: In Transit
Country: China-> Canada
Destination:
Place of shipment:
2020-11-01 05:07, Guangzhou, delivered to the carrier for transportation
2020-11-01 03:02, Guangzhou city, leave [Guangzhou International center], next stop [Guangzhou International Exchange Station]]
2020-10-31 16:45, Guangzhou city, [Guangzhou International center] has been exported directly
2020-10-31 16:45, Guangzhou city, [Guangzhou International center] return, remarks: Security Check return
2020-10-31 16:40, Guangzhou city, [Guangzhou International Exchange station] return
2020-10-31 11:39, Guangzhou, delivered to the carrier for transportation
2020-10-30 11:22, Guangzhou city, [Guangzhou International center] has been exported directly
2020-10-30 11:22, Guangzhou city, [Guangzhou International center] return, remarks: Security Check return
2020-10-29 20:49, Guangzhou city, [Guangzhou International Exchange station] return
2020-10-20 04:32, Guangzhou, delivered to the carrier for transportation
2020-10-20 03:42, Guangzhou, arrive at [Guangzhou International Exchange Station]]
2020-10-19 22:02, Guangzhou city, [Guangzhou International center] has been exported directly
2020-10-19 19:40, Guangzhou city, leave [provincial international Huadiwan business department], next stop [Guangzhou International]]
2020-10-19 18:48, Guangzhou city, [provincial international Huadiwan business department] has been received and sent, and the investor: Huang Mingzhong 1, tel: 17391391390
Alibaba Translation
包裹是因多次安检不合格,重新发出,导致一直在中国运转
The package was reissued due to several unqualified security checks, resulting in continuous operation in China.
And another response later......
安检不合格的因素有很多,所无法规避这种情况
There are many factors that fail the security check, which cannot be avoided.
Alibaba Translation
只希望包裹幸运一些,不要放在无法出口的集装袋中;包裹就能很快通过安检,交航飞往加拿大
I only hope that the package will be lucky and not put in the container bag that cannot be exported; The package will pass the security check quickly and be delivered to Canada by air.
And another...
朋友,这个我没法给你准确的答复,如果安检很顺利地通过了,那么由中国飞往加拿大,,再到送到你手上,快的话30天左右就可以了。如果安检依然不太顺利的话,我也没法预测包裹什么时候可以送到你手上。
My friend, I can't give you an accurate answer to this. If the security check passes smoothly, then fly from China to Canada, and then send it to you, if it is fast, it will take about 30 days. If the security check is still not smooth, I can't predict when the package will be delivered to you.
Nice score - do you have a picture of the data plate?
Can't seem to get an image of it, the flash keeps washing it out. But all it really states apart from some part number and S/N is
1PH AC220V 50/60Hz
3PH AC220V 0-800Hz 3.7KW
Thanks.
Was just concerned that they shipped you the 0.4KW power unit and not the 3.7KW one. The add seems to show a bunch of options when it come to rated power.
Looks like you are fine.
Thanks.
Ya, I found that a little confusing as well, but the ad title did clearly state 3.7KW. The price was more in the 0.75-1.5KW category, but the regular price was more on the 4-5KW category, so I took a chance. I could always contest (or try to contest?) what was sent as not as advertised.
Spotted this on Amazon.ca yesterday and ordered it..
.. BUT...… the instruction/programing manual is in Chinese😳
I have an app on my phone that will take a picture and then translate it. The results vary from fairly good to gibberish. It might work well enough to cross reference to an English one.
What do you figure.... should I believe this or not????
I was just about to raise a dispute on this order. It was returned to the shipper 4 times since mid Oct.
In stark contrast I have a rotary table on its way from India. Shipped on the 20th, should be here tomorrow as it landed in Victoria yesterday.
Keep the faith Craig!
