Active project - 1972 MGB
Yes that one looks a bit on the tired side. Just a note, you can get a thing called a speedy sleeve, that is pushed on over a worn hub/shaft to give a new wear surface, they usually come with a seal, least way the ones I have used have. So far a couple of Cummins pickup engines, various tractor engines. Don’t know if available for everything, LOL.
Note, a outer ring can move on a harmonic damper when aged and miss up engine timing, causing some hair pulling.
I know speedy sleeves are available for the flywheel end of the crankshaft where it goes through the main seal. No idea if on is available for the crankshaft pulley.
I hope you have help with pulling some things out it makes it so much easier.
Nope, total solo effort. Made slightly harder because I didn't remove the correct transmission mounts. There are five different mounts...I went for the easily accessible one and the bloody transmission crossmember didn't drop to the ground when I was lifting the engine out.
Couldn't get under the car because the hoist was in the front, the Quickjacks prevent side entry and the car was backed up as far as it could go so I had room in front of the car for the hoist. With the engine suspended in the air I then had to use my extra long arms to reach way the hell down into the transmission tunnel and unbolt the mounts I could reach and pry the crossmember off with a pry bar.
Still I had the engine out in 90 minutes. 🙂
Unfortunately with the Quickjacks both sides operate simultaneously so I would have to block both sides.
New shoes for the B
I wanted to fit 15" wheels to the B so that I had access to better tires.
The typical aftermarket wheel option is minilites but I didn't want to go that route because a) that's what everyone else does and ) because they cost a small fortune. Well over $1000USD for a set of four.
Turns out that 2000-2002 Volvo S40 wheels fit perfectly. Found four wheels locally for $396 and bought four 196/60-15 Goodyear Eagle RS-A tires online for $400CAD.
Mounted and balanced under $1K
Very happy
First the blower, now the wheels.
What will be next?
Creeping towards a restomod….. it’s a slippery slope.
I really enjoyed making modifications that reduced weight while simultaneously added performance. Weight especially unsprung is the enemy.
I really enjoyed making modifications that reduced weight while simultaneously enhancing performance. Weight especially unsprung is the enemy.
I don’t recall the exact numbers now (spreadsheet somewhere), but more than 450 lbs.
Aluminum heads 50
Intake & pump 30
Flywheel 15
Fiberglass leafs 60
Hydraulic to EPS 30
TCP R&P, aluminum shocks 30
Fold down rear seat to Shelby tray 65
Aluminum 5spd 35
Rims 50
Heater core 25
Fiberglass hood 35
Brakes 30
450 lbs or 4/10s or 4 car lengths and much better handling.
4 cylinder MGB engine weighs more than my small block ford
Most of that appears to be sprung weight. Obviously still beneficial cuz weight is always bad.
Short inside story - manufacturers test fuel economy and emissions by weight category, not individual weights. So manufacturers go crazy to find ways to reduce the weight of a model to get it into a lower test weight class. Everything is fair game from changing materials to skeletonizing parts. Sometimes the part cost goes up, but the test class goes down so it's still worth doing and customers always like it!
Yet the weight keeps going up (significantly), even with all that plastic and aluminum.
I realize some small amount is for safety( how much does a door side bar weigh 5 lbs?)
It’s mostly all the creatures comforts, but an extra 1000 lbs, that transforms a sports car into a sled.
If you want to build a sports car, start light and then make it lighter.
