I know speedy sleeves are available for the flywheel end of the crankshaft where it goes through the main seal. No idea if on is available for the crankshaft pulley.Yes that one looks a bit on the tired side. Just a note, you can get a thing called a speedy sleeve, that is pushed on over a worn hub/shaft to give a new wear surface, they usually come with a seal, least way the ones I have used have. So far a couple of Cummins pickup engines, various tractor engines. Don’t know if available for everything, LOL.
Note, a outer ring can move on a harmonic damper when aged and miss up engine timing, causing some hair pulling.
Not a chance. He's already way to quick with these projects. I mean engine and transmission come out and then the new harmonic balancer is machined. All in 20 minutes and the rest of the day one long coffee break admiring his work...I hope you have help with pulling some things out it makes it so much easier.
Nope, total solo effort. Made slightly harder because I didn't remove the correct transmission mounts. There are five different mounts...I went for the easily accessible one and the bloody transmission crossmember didn't drop to the ground when I was lifting the engine out.I hope you have help with pulling some things out it makes it so much easier.
I hate to disappoint... but I still need to machine the new harmonic balancer, 🙂Not a chance. He's already way to quick with these projects. I mean engine and transmission come out and then the new harmonic balancer is machined. All in 20 minutes and the rest of the day one long coffee break admiring his work...
I don’t recall the exact numbers now (spreadsheet somewhere), but more than 450 lbs.
