Yes that one looks a bit on the tired side. Just a note, you can get a thing called a speedy sleeve, that is pushed on over a worn hub/shaft to give a new wear surface, they usually come with a seal, least way the ones I have used have. So far a couple of Cummins pickup engines, various tractor engines. Don’t know if available for everything, LOL.
Note, a outer ring can move on a harmonic damper when aged and miss up engine timing, causing some hair pulling.
