2x72 grinder discussion
Re: I might give my local laser cutting service a go for this.
If you go ahead, can you let us know what the quote comes out to? I probably have enough steel in the junk box and I have a band saw but I like the idea of the precision slots for alignment and I don't like the idea of that much band sawing. I am also in Victoria so a local supplier would be good.
Will do.
Ok I sent off the 13 dxf files to Canada Laser Cutting for an estimate.
Ok grinder aficionados grinder motor choice advice needed.
Trying to decide if I want to spring for a 1-1/2 HP 3-phase motor.
I already have a single phase, 3450 rpm 1 HP Baldor motor like the one below. Runs perfectly.
Is the variable speed and additional 1/2 HP super desirable?
When I built mine I messed up and bought a 1.5hp 3 phase 1750 rpm instead of 3450 rpm. Running it at 90 hz mostly solved the belt speed issue, but I do like the variable speed given that I use it for metal, wood and plastic. Unless you are making knives or running a fab shop I think you wouldn't need to move to 1.5 hp.
I would definately recommend variable speed.
3450 puts you up in metal territory. If you want to be able to sand wood or other materials without burning, or sharpen knives, you’ll want to turn it down.
Not to take the discussion on a left turn but I really like some of the ideas in this build:
I have a small shop and am always on the lookout for small and portable solutions. His hinge design is inspired and definitely thinking outside the box. He is using much lighter material which would be a lot cheaper. I probably have most of what I would need in my junk box.
Brian
My last one is pretty similar to that, also just 1/4 plate and 1x1 tube
only thing required to use 2x72 belts is longer arms on the platen holder and ?work shelf?. but as it is with the 2x48 belts it takes up quite a bit less space
That's the biggest reason I went the laser cut route. I kinda detest grinding metal because of the mess it makes.
Effective dust collection was a big initial driving factor behind doing my own design, as I wanted to incorporate it from the very beginning, and not just slap something on as an after thought. I kept up with the changes through the first few iterations, but some of the latest add ons made me abandon the dust collection updates, so at this point, I think it'll mostly be an add on afterthought.....Exactly what I was trying NOT to do. :D
A tilting belt grinder is a lot like a compound mitre saw from a dust collecting standpoint. Difficult to contain, as there are many dust generating points that are difficult to access. The more I got thinking about this, the more I'm leaning to an overall "cubby" the grinder sits in, vs trying to contain the dust at the source with shrouds and stuff like I was initially trying for. With all the add ons, and rotating design, it really makes it challenging to do it any different.
I was curious about dust too. Seems like a lot of knifemaker guys have a 5-gal pail underneath, some containing a couple inches of water. Presumably serves to both catch majority of grindings for easier sweep-up & also immediately extinguish them. Now if you have belt head orientated in horizontal mode, just rotate picture 90-deg either way & yeah, different considerations. But I wonder - is 90% of the ground material contained within this kind of spark cone immediately below the grinder & the rest is airborne settling somewhere else in the shop? I'm thinking metal cant fly very far like wood dust can, but obviously some does.
I've been thinking about some kind of spark catcher, once I get the machine built, the plan is to play around with some thin heating duct sheet metal to come up with a design to accommodate both vertical and horizontal grinding.
The vertical collector could be something simple like the first pic but with a wider funnel, the horizontal collector will be tougher as it has to catch the spark cone and not let it bounce back out.
Maybe something like the shape of the mitt used by Jai Alai players as in the second pic.
The inside surface of the scoop might have to have some kind of bounce reducing material to help direct the sparks down into the collection bucket.
The horizontal collector might end up just using the vertical collector tipped sideways.
  • Screenshot 2025-02-03 at 07-41-25 Metric Plan Bundle Gen 2 Belt Grinder Attachments - Etsy Can...png
A 5gallon water bong setup with a vac might work pretty good for dust/spark collection.
I made one for my blasting cabinet to catch the majority of the debris before the shop vac.
Just watched Phil Vandelay's last installment where he constructs dust/spark containment, I think I'll go with something like that.
Just a note for anyone thinking about building a 2x72, take note of the length of the footprint, Jer's Gen2 has a minimum length of 34", with a catch pan, 38-40".
For some reason I thought it was shorter and the spot I had planned for it is not going to work, wishing now that I had gone for a 2x48 instead.
Identical capabilities but compact.
