Aw leave them alone, they don't look ugly, they look light.i will powder coat the tanks, they are kind of ugly.
No grams are free.
Ryan dude ouch. Sadly been there done that. There is always a story.smooshed my finger at work on wensday (today).....oops
I have done a few tow bars. I like a round handle, even standard 1/2 to 3/4" pipe works well., maybe I have girly hands....
I used a spring to hold the moving arm to the fixed arm and weld a piece of 3/8ish rod to the moving arm as a counter lever. I tried to do sketch but it was easier to run to the shop.
This was originally on the C150 but is now for the RV4.
Are you going to finish with fiber glass and resin?started on the cowling while i wait for a few invoices to roll in, a relatively low cost high time item. I could purchase this, but the nose piece and the sheet metal is just south of 1000$ usd + shipping, with our dollar i think i will spend the time and effort
im 4 cans of spray foam into it thus far, probably need another 2 before i can get to the shaping, and likely 1 more to fill in large voids before i can get to drywall compound for the smoothing. This is the progress so far, im going to let what foam i have on there cure over night, rushing putting on that spray foam overhead doesnt work, one layer at a time, might take a few days to get it filled in
View attachment 62434View attachment 62435View attachment 62436View attachment 62437
@phaxtris your timing is spectacular! I too am working on my cowling. I have to remove the original air intake and install one to accommodate an air filter. I built up the cowling to fit the profile of the new intake, but was wondering what to do next. I also was looking at different profiles for the final look. To make the new intake match the old cowling, it was suggested to use bondo, but that turns out to be expensive and hard to work with (if left too long, which I seem to do) I was just discussing using spray foam today with a friend, and I also wondered if drywall compound could be used to finish the final shape. Today's post by you answered that!
Thank you!
Nice! is the last photo "cowling mod" all finished up ?
No, I am still at the fitting stage. The one labelled "cowling mod" is where I am at. I built up bondo until the gap was filled under the new intake, then I am going to take a contour out of the old cowl to make a better transition into the new intake. That is where I am going to try spray foam.
OK. Thanks for the input. I was wondering if one type of spray foam had advantages over another. But I was thinking more the sanding/shaping aspect. Will get some low expansion foam tomorrow.
Nice work Ryan !!it has been done for about a week now, just removed it from the mold today, here is an update
a little bit every night, sand, drywall mud, add foam to the bottom....rinse and repeat...8 cans of spray foam an a whole bunch of drywall mud later..
getting the foam built up on the bottom has been a slow process, one layer per night, but finally enough is on there to carve some shape to it and start adding the drywall mud
View attachment 63162View attachment 63163
spray adhesive, cellophane and Vaseline as a bit of a release and its ready for some glass
View attachment 63164View attachment 63166
the remnants of the mold, and the cowling pieces baking in the sun, 4 layers of cloth on top and bottom, it will need some strand matt on the inside, they are still quite flimsy and thin...this will probably be on hold for a while, the prop for the other plane came in so i have been back and forth to vulcan getting that bolted on, timed, and working on starting it, hopefully flying will eat into the summer project time
View attachment 63167View attachment 63168
