You guys are a bad influence
There's a lot of great content above.
Here's a few things that will help you get from "I'm not sure' to 'I can do this':
Always look for the ways thing can move, even if you think they can't.
Make every move segment planned, with safety of 1) people 2) the facilities and other equipment present 3) the item to be moved
The result is to have zero unplanned movements.
It is better to have 1" of progress than 1' of danger.
all suspended loads can fall.
all loads on rollers can move on their own.
keep checking that the load or lifting equipment cannot fall over
how I got started: I had a 1700 lb milling machine that was on a trailer, 12" above a gravel lane, 30 feet from my garage. the lane was on an 8 degree slope and it was above the garage. I used a pry bar, 2X10 lumber, wooden wedges, pipe rollers and plywood to move it by myself into the garage. It took 6 hours.
Finally - if you don't have patience you aren't right to move heavy stuff.
@Brent H - you forgot to mention your wench Bertha! :D
You guys must have all been biting your tongues back a few months ago when I posted a picture of my little loader tractor taking my Bridgeport off of my flatbed...... :rolleyes:
Whatever works and gets the job done safely. All that maters.
It worked, but at the time I figured it was only a few more pounds before the rear wheels came off the ground or the hydraulics maxed out.
In hind sight, prolly the worst thing I did wrong was doing it alone without a second pair of eyes. Should have called a neighbour over.
But the biggest one of all - if you need a heavy lathe moved out of a basement- don't call me :) (just kidding @Canadium - we rocked that move!)
Brent and his boys are my heroes for that lathe move. They saved my skin. If it wasn't for their help I would have been in deep doodoo! Thanks again Brent and thanks again to your great boys!
See? Always keep something between you and the piece that can bite you!:D
(Totally just a joke please do NOT do this)
While gently disassembling this the part where the taper pin fits fell off. A year or two ago I talked to my local machine shop about moving the pin spot 90 degrees. He said sure bring the drive wheel back with the shaft. I took the part where the shaft rides too, so hopefully he can make all 3 pieces work together
I have one contact on the motor to solder but I had an electrician look at it in the early spring of 2021 (I think) so I know the motor works.
Fingers crossed @YYCHM I have a good feeling 2022 (2023 for sure) I’ll have this back together
