Here are a few more tid bits:
If you are going for the big distance move:
-Ensure the machine is fully disconnected from all power.
-Lock or seal shut any doors that can fly open
-be sure all loose items are removed from the machine and put into manageable containers
-Drain all fluids and wipe off grease and oils that can cause grip issues or get you and your lifting arrangements all slippy
-Make sure the exit path is clear and measure the route to make sure you can fit the machine out the doors
-If you have the machine on a cart or other rolling carrier - secure the machine to the carrier, make sure the carrier cannot free roll away or towards you - into a wall, down the stairs etc
-be sure to balance the load for a lift - pick it up so it stays level - use a spreader if required
-don't over sling the lifting hook - use rated shackles, cables, slings chain falls etc
-protect the stairs, exit pathway, floors etc from damage
-properly secure top heavy equipment - always best to take it apart if possible . - like take the base off the lathe or fold a mill into the proper head position for moving.
-if possible take the machine apart into manageable sizes
-watch sharp edges and protect the lifting straps - watch chains on equipment - things like cast iron can shatter if reefed down to secure them
- remember that if the lift is on an angle your arrangement may be de-rated given the severity of the angle - like a chain fall that lifts 1 ton does it straight up and down - not hauling a lathe up the stairs where the connection point is at an angle
- lathes roll really well on cement floors with a couple steel pipes - as do mills
-Try and look up the weight of your machine - heavy stuff is typically listed in the manual - make sure your gear is good to go for that.
-avoid using pulleys or ropes that you are just physically holding and pulling on to lift the machine - best to have something that locks the position with each advancement of motion.
-if you are craning things - use a tag line to help control the load
-DO NOT WALK OR GO UNDER THE LOAD
-discuss signals and hand gestures or have a line of communication if you do not have direct site of the person operating the winch or chain falls
- try and establish rest areas in the move where you can get the object to and then take a safe break if required.
-Beer etc best served AFTER the move
-make sure your trailer can take the load - secure the trailer from tipping if it is off the truck ball - never hurts to throw a couple jack stands under the back end for support.
There is lots more but I gotta go see some contractors...
But the biggest one of all - if you need a heavy lathe moved out of a basement- don't call me
(just kidding
@Canadium - we rocked that move!)
