Nice bike!I made a handlebar! This style of bar is called a bullmoose bar, and is sort of neat because it is integrated into the stem. I missed pics of a couple steps. The bar material is 7/8" x 0.049" 4130 from McMaster-Carr. It ended up being cheaper to buy from mcmaster even with shipping then it was to buy from spruce aircraft.
First I bent the bar and then coped and welded on the truss bits, and then coped the ends simultaneously for the steerer tube end. I wasted several hours trying to cope both ends of these truss tubes and get a good fit up because I did not want to remove my vice and un-tram my mill lol. I should have just did this in the first place.
I prepared the binder clamp pieces on the lathe and brazed them to the steerer clamp portion, then slotted it so it could do it's pinching action. I mounted it to the end of my fork and then put the whole fork in my tube clamp setup, and then positioned that above a 1:1 scale drawing of the bar for fitup. I tacked it in place and then welded it together.
Its about 780mm wide right now. I think I'm going to ride it for a bit but I'll probably end up trimming it down to 740mm wide.
(What make model of moto is that?)
