My lathe has the typical cross slide lock screw going in laterally against the gib strip. Its pretty common on Asian machines. There are better ways of doing this but it is what it is. One thing I dont care for is a typical perpendicular ended fastener makes mor less point contact with the gib. So its not the best for retention, tends to make bite marks on the gib & actually can displace the cross slide just by tightening. This is the first thing I noticed when I installed DRO, tighten the screw to lock position & DRO shows it displaced X thou even though the dial remains on same visual DOC. If you can put a ball end on the screw, better yet a floating ball, that would be better. Somewhere on the forum I snapped a pic of mine.
