Working on my South Bend 9C
On th SB I believe the gibs all have a recess that the adjustment bolts sit in. At least on the cross slide. I'd have to pull the compound to confirm.
May give the dumbbell test a go today
My lathe has the typical cross slide lock screw going in laterally against the gib strip. Its pretty common on Asian machines. There are better ways of doing this but it is what it is. One thing I dont care for is a typical perpendicular ended fastener makes mor less point contact with the gib. So its not the best for retention, tends to make bite marks on the gib & actually can displace the cross slide just by tightening. This is the first thing I noticed when I installed DRO, tighten the screw to lock position & DRO shows it displaced X thou even though the dial remains on same visual DOC. If you can put a ball end on the screw, better yet a floating ball, that would be better. Somewhere on the forum I snapped a pic of mine.
Perhaps a brass slug with the appropriate angle on the end, pushed by a set screw would be even better ?
Duh, seems like I forgot my own mods. This is what I did. The end of toghtening bolt has a half spherical pocket (ball end milled). It pushes on the bearing ball glued into this brass plug. The other end of plug has a matching dovetail angle to gib strip. So near zero friction & more face to face contact.
I'll post this here because its relevent to the discussion. But maybe someone can check my math & other assumptions. Barring any errors I think its an intersting visual representation of bed twist effect using the typical dial indicator on a test bar method. At least I've never seen it summarized & correlated in this manner. Of course this assumes a perfectly straight test bar aligned to spindle socket & all those issues, but actually even this can be compensated for (save that for part-2).
The RH sketch shows the end view of lathe with example input dimensions. A 1" diameter test bar. The test indicator assembly is the L shaped solid line. Dashed line is the dial plunger distance. If the bed is twisted, L rotates counterclockwise relative to neutral axis, the dash line grows, I subtract the difference of this from 2.5000" reference distance at zero bed twist. The (example) 0.005" is the distance the L corner has displaced vertically. Hopefully this makes sense. I could have input a twist angle & yielded dimension, same thing.
On Michaels lathe, when we initially thought we were looking at a relatively BIG indicator reading difference from HS to TS in the 0.016" range, I made a series of CAD calculator sketches & worked out the equivalent bed angle twist backwards. When you plot a series of different bed twist angles, not surprisingly you get a linear relationship. More bed twist = more dial indicator reading. And this factors the ball end of indicator end coinciding with a circular section test bar, ie. it contacts high or low relative to spindle center line. I improved the chart a bit to show a typical Starrett 98-series level on the left Y-axis & equivalent angle in regular degrees on right Y-axis. We are talking tiny amounts of twist here, one line increment of Starrett-98 is 0.005 innch/foot. So the way to read it is: take your dial reading difference from both ends of test bar (0.005" on chart) go up to intersecting line in either direction. Blue = Starrett level scale (about 3.5 ticks or 0.018 inch/ft). Or go to orange line scale for equivalent angle ~0.075-deg.
So the takeway point is, on this example setup, 1 line increment of Starrett bubble level corresponds to ~0.0015" dial indicator reading difference
I can adjust the shims more. This was with a .005" shim, so to go closer I'd need to stack smaller shims together (I'm almost positive jumping down to .004" shim would overcorrect).
