Golem Pens
Michael
I kind of reckon trying to get closer with this config is a fools errand. So, really debating if it's time to turn to the headstock.
With a short bed, any adjustments at one end really show up at the other too.
Here you go.So the before condition was 3 ticks * 0.024 deg/tick = 0.072 deg of total twist from HS to TS? Again maybe half that amount mid span where your carriage was traversing when you measured the big-ish dial indicator reading? And this twist direction is confirmed in the runout adding or runout subtracting direction in terms of your test dial reading?
Time to put your test bar back in & replicate prior reading as a spot check. I'm going to wager minimal improvement with the shimming.
I'll poke at it more tomorrow when I have more time.This is what drives most guys crazy.
That is always going to happen.
It's yet another reason that I like to use gauge pins.
Three things.
1. Figure out what the ratio is between a change at one end and the resulting change at the other. Knowing this ratio allows you to get closer faster.
2. Sometimes you can't get there because of stored stress in the bed. When this happens, let it sit overnight or over a week. Eventually it will relax enough to get there.
3. Gotta know when to quit. For me, it's always a lot less than 1 tick on the level. Maybe 1/4 if a tick?
Also, dont forget to check repeatability. If you can't get repeatable readings, then you don't really know anything.
It's interesting that you tested at 4 points down the bed. I have done that in the past too. It has never proved to have been worth doing.
How does using gauge pins (I assume you mean on top of the v block, under the level) help tackle this more than just the blocks?This is what drives most guys crazy.
Testing at 4 points was just out of interest.
Unfortunately mine only has 2 feet 😉
I'm of the opposite opinion (see #1742). If you are within 1 or 2 ticks of bubble level down the bed, I just cant see this small amount of bed twist accounting for 0.016" dial gauge deviation on your prior test bar evaluation (or whatever the recorded amount was). Just park the leveling equipment for now & try & replicate the test bar as-is because it looks to be the elephant in the room. If your 0.016" deviation is now 0.015", congratulations, you improved it 6% & confirmed something important. But the culprit is looking more like HS rotation IMO.
