And plan for the worst (fire/burn). Did a 30 second weld last night, walked to a machine to test fit my piece, turned around and my work-bench 4' away from the welder was on fire. I had (past tense) a blue shop towel under a crank-shaft for a tractor. Spark ignited it and the residual oil from the crankshaft that had soaked into the towel fueled it.
All is well, was able to snuff it without extinguisher, but real example of how fast it can get away from ya. Fire extinguishers are a must, as is a bucket of sand, first-aid-kit.
thanks - I checked the link and i see i can buy in usa, i will look for it here- i will call liquide and few othersHey Ken,
I used to have some really good luck with a rod "Certainuim" I think it was - Purple flux coating and 1/16" diameter - worked well on the small stuff and multiple metals.
https://www.lawsonproducts.com/Certanium/707-Dissimilar-Steel-Stick-Rod-Electrode-116/P12655.lp
Not sure of a Canadian supplier - probably available at air liquide
Dissimilar metal electrode
Also check Canadaweldingsupply.cathanks - I checked the link and i see i can buy in usa, i will look for it here- i will call liquide and few others
good info - wife may think it is bit expensive for wiener roasting sticks- but then it is for killing time thks
thanks - i see a small quanity looks perfect i will look for it locally and try to avoid shipping cost here is link to the shopping cart i made thereAlso check Canadaweldingsupply.ca
what is Miller 252? what are stich timers? spot timers? where are you?Millar 252 no longer available new
stich timers, spot timers
I suppose the programmable features is the short answer
#1 252 is a mig machine
spool gun ready plug and play I see another listed by another member
#3 Spot timer is 1 of the features which can be programed to suit the jobs needs - pre flow of gas post flow burn time to suit the wire size your using matl. thickness etc. as it sounds you burn thru 1 layer and fuse it to the base layer you need a different nozzle that's notch so when you hold i against the 2 layers as a vented stand off for the tip
#2 Stich timer; after setting the machine voltage-wire speed to suit material you can also set pre flow- post flow of the gas your using - burn time- dwell time period between next burn I use these 2 programs for body work I like it, does what I need it to coffee can to !"
search it out for more info at Millars site
#4 Hiding in the woods shhh
Shows on lawson Canadian site.thanks - I checked the link and i see i can buy in usa, i will look for it here- i will call liquide and few others
looking for info - i have an old forney ac stick welder, and an acetlene torch - I am looking for help making some weiner roasting sticks for gifts, i use 3/16 cold rolled rod for the stick and 1/8 stainless steel for the forks, in past i have tried and had some success and lots of failure using bronse torch, and more of same using various ac rods 7014, 6011 . I usually end up burning completely through the stainless steel. I am looking for suggestions of ac rods and ampes to use. I am open to any and all help I do NOT have mig or tig and have no room in workshop for them
