....... a clean shop is the sign of a sick mind, your in good company here. 😉
I LOVE having a clean and organized shop. But it's something that exists only for a brief period of time when I finish a bunch of projects hanging around, and start putting stuff away, or making homes for things that don't have one. Once that is done, new projects begin, and all hell breaks loose again.
There are too many projects on the go right now, and I have been too busy with work all summer to make any headway into them. Not to mention bringing home a lot of scrap and offcuts that pile up.......I either need to stop bringing stuff home, or I need to build another stock rack for it. I'm back to bucket storage because it's easy, and easy to move around, and I HATE that......
I really just need a bigger shop.....That would solve ALL my problems.
I look at my goal of having a clean shop in the same way I look at my finances........
I am happily working on my second million......... after completely giving up on the fiasco of the first one. 😉
A friend up the road just dropped this off asking if I could fix it......worst spot it could break. I told him id take a crack at it, but there are no guarantees, and to bank on buying another anyway, but this might get him through the winter plowing snow.....
Tacked for alignment, will groove out one side at a time for a full pen weld. Pre/post heat of course. I am reasonably sure They are cast steel, not iron, verified via spark test.
If these had been red, they wouldn't have broke......
Ill update when done
Any chance of adding a reinforcing plate on either side or would the additional thickness be an issue?
Vee'd out the crack to just below center and tacked on some run off tabs. Preheated it with the tiger torch. Welded with 1/8" 7018 around 130amps
Not bad, coulda been better....Flipped it over, cut those tabs off, and snapped my backing rod off.
Vee'd that side out again, past center. Then preheated it and repeated the process....
Put the torch on it again, then wrapped in in a blanket to cool down.
I'll try and find that hole again after dinner. Gonna be covered in burr chips for a while......
We'll see how this pans out. I'm about 70% confident it'll be fine. I gave it a fighting chance, but it's a terrible spot for a repair.....
I haven't got the story on how he broke it yet. 30hp JD scut. Gotta be a good story......
I had that though initially so I had him bring over the lifting arm too, but there's no room on the sides there without making a science project out of it.......I could maybe plate it with 14ga on both sides....I have a bit of room on top to weld a 1/4" bar across it, and more room on the bottom. I'll clean it up once it cools off and make the decision.....I also thought about boring the hole bigger and sleeving it too. I'll probably do something, all depends on how good I am at finding that hole again.....
Finished. Managed to nail the old hole dead center. I'd rather be lucky than good.....😀 Only a little bit of burr work to blend and clean up. Also managed a complete fill after flap wheel cleanup so I didn't have to add anymore weld anywhere to eliminate stress risers. . I don't have any expensive green paint, so it's going back naked. Hopefully it holds. For a winter anyway.
Lunch, then SSQA bracket.....I bought another plate for the bucket which showed up yesterday. Guy didn't look too happy carrying it off the truck 😳
Despite my suggestion of only using it to plow snow for the winter while looking for another one, he put it right back to work grading with a box blade, and it's held fine so far. He hooked a root while grading and that's what broke it the first time.
